List of engine combos
- Downsouthdio
Re: List of engine combos
1. Af16e
2.polini corsa
3.44.4 teflon insert ministroker
4. 30mm oko, uni pod
5.scorpion pipe
6.matched boost port
7. Ruima 6.8
8.93 oct. ,32:1 premix, klotz
9. 51 /140
10. Key west fl, sea level
2.polini corsa
5.scorpion pipe
7. Ruima 6.8
9. 51 /140
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
TOO MUCH CARB!
af16 fully ported!
mhr malossi
mhr malossi crank
ct black with boyseen reeds
28 oko
pg long
s trans
7.4 or 8.1 gears
mhr malossi
mhr malossi crank
28 oko
pg long
s trans
7.4 or 8.1 gears
- Downsouthdio
- Downsouthdio
Just an extra till i get around to buying a 28.. But it does work pretty much just like the 28mm i had before
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- Trafficjamz
Downsouthdio wrote:Just an extra till i get around to buying a 28.. But it does work pretty much just like the 28mm i had before
there is very little difference between the 30mm and 28mm carbs
- Downsouthdio
That what im saying.. Everyone trys to say good luck tuning and all that., from having 28's and 30's , its close to the same.. Jetting starting points are a little different but tuning wise seemed almost the same to me.. Ive seen 33mm on elites before.. Dialed in!
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Yeah and the oversized carb kills the bottom end throttle response.Downsouthdio wrote:That what im saying.. Everyone trys to say good luck tuning and all that., from having 28's and 30's , its close to the same.. Jetting starting points are a little different but tuning wise seemed almost the same to me.. Ive seen 33mm on elites before.. Dialed in!
- Downsouthdio
88 SA50 with
AF16E
Left, right carters and boost port were matched to an interesting 49mm aluminum bore that was meant for either a 49mm or 50mm crank.
50mm cast bore from Taz
44.4 mini stroke crank
Oil pump plug
28mm OKO
Needle at 2nd notch from bottom
Pilot jet 50
Air screw 1 1/2 turns out
Main jet 154
91 or 93 octane non ethanol fuel
32:1 premix Bell Ray MC-1
Scooter alley exhaust 72-90cc
K&N cone shape metal mesh and paper ish type
B7HS NGK Plug
IL 700-900 ft above sea level
Temps unknown, WOT temp unknown
8.0:1 gears
Polini Variator
Either Polini belt or Honda
Home made Variator shim
Oem drive face and oem clutch with bell
Polini main spring and Malossi black springs
Metropolitan wheels
90/90-10 tubeless tires
AF16E
Oil pump plug
28mm OKO
Pilot jet 50
Main jet 154
B7HS NGK Plug
8.0:1 gears
Polini Variator
Metropolitan wheels
