Test results.. "Big" CT Black vs CT Black
Re: Test results.. "Big" CT Black vs CT Black
Its a stuffer... it just takes up volume between the carb and the reeds. They usually give you a couple different sizes and you use the size that matches your carb... example, if you run a 28mm carb you use the 28mm size stuffer.
