27mph thread
Pierce ramsay
Re: new 27mph thread b/c the other one got locked
Post by Pierce ramsay »
stock carb and exaust?
jet size?
when you grab more that 1/4 throttle does she sound like she is throaty or deeper before she dies? like to much fuel not enough air? grab a new air filter or a aftermarket airfilter.
iceman77
Post by iceman77 »
Pierce ramsay wrote:stock carb and exaust?
jet size?
95 jet
sounds good when at 1/4 throttle and sounds good when more than that but only for like 5 seconds then sounds really deep
Mystic
Post by Mystic »
try moving the clip on the main needle and see what if any difference that makes.
iceman77
Post by iceman77 »
Mystic wrote:try moving the clip on the main needle and see what if any difference that makes.
will do. i'll try that this evening when i get home.
iceman77
Post by iceman77 »
i moved the clip and changed the spark plug. the only difference it made was when it warmed up i can get to 25mph then it dies for like a second the picks up again till 25mph then does it again.
so :confused:
Mystic
Post by Mystic »
did you move it up or down? be careful running WOT on a new bore expecially if you leaned the needle. clip up on the needle leans, down richens
iceman77
Post by iceman77 »
Mystic wrote:did you move it up or down? be careful running WOT on a new bore expecially if you leaned the needle. clip up on the needle leans, down richens
i moved it down so it would get more fuel.
Pierce ramsay
Anyone else think it might be the reed valves or in the intake some where?
iceman77
Post by iceman77 »
the stock needle only has 3 notches so i made 2 more notches and moved the neddle down and the lowest one worked like a charm. she'll do 35mph now w/ no problem at all.
Post by eliteguy50 »
iceman77 wrote:the stock needle only has 3 notches so i made 2 more notches and moved the neddle down and the lowest one worked like a charm. she'll do 35mph now w/ no problem at all.
You moved the needle down or the clip down?
iceman77
Post by iceman77 »
sorry. i moved the clip down. there for bringing the needle up
If you run out of clip notches, that is usually when you upjet.
tazland001
Post by tazland001 »
He got it running. He had the stock air box on. Cannot run a 95 main jet with the stock box on or it will choke on mid and top. Problem solved.
Taz
iceman77
Post by iceman77 »
thanks again for the help taz
Mystic
Post by Mystic »
the 66cc kit you are running should do more than 35 mph. are you still running stock gears? my 43mm kit with 9.1 gears does about 45, it was sold as 65cc but i think its actually more like 60cc. Glad you got it running smoothly now you gotta fine tune it to get the most juice outta that sucker
