66cc bbk. which gears would be best for me to get
bakaracer
Re: 66cc bbk. which gears would be best for me to get
Post by bakaracer »
Why go 66cc when you can go 72cc or 78cc for the same price if not a few more dollars and get more torque which is what you need if you live where there are hills the 72 and 78cc cylinders can still be run with the stock carb and exhaust and still get real good performance that sips gas and way less noise.
iceman77
Post by iceman77 »
bakaracer wrote:Why go 66cc when you can go 72cc or 78cc for the same price if not a few more dollars and get more torque which is what you need if you live where there are hills the 72 and 78cc cylinders can still be run with the stock carb and exhaust and still get real good performance that sips gas and way less noise.
I didn't think i could still use the stock carb w/ a bigger bbk. that's why i went w/ the 66cc. live and learn i guess.
gixxer1000chad
Post by gixxer1000chad »
yeah you can use the stock carb with the bigger cc bore kits... wheelman has an interesting thread about modifying the stock carb for that reason.. in fact i think he is trying to sell one thats modded....... viewtopic.php?f=2&t=21449
i bet mine is slower!!! now what??
iceman77
Post by iceman77 »
gixxer1000chad wrote:yeah you can use the stock carb with the bigger cc bore kits... wheelman has an interesting thread about modifying the stock carb for that reason.. in fact i think he is trying to sell one thats modded....... viewtopic.php?f=2&t=21449
well dang. too late now. i got the 66cc in hand.
iceman77
Post by iceman77 »
if i can get 50mph or a little better i will be happy w/ this.... for now :smile:
bakaracer
Post by bakaracer »
You only need to mod the carb if your NOT using an airbox. You can still use a stock carb unmodded and airbox with the 2nd tab punched out with a bbk with stock exhaust. If your using an aftermarket exhaust,you need to run a larger carb to match the exhaust or you risk seizing.
bakaracer
Post by bakaracer »
iceman77 wrote:if i can get 50mph or a little better i will be happy w/ this.... for now :smile:
If you already have the 66cc kit then use that. Just make sure that the boost port on the bore is the same size on your engine case, if not you will have to match it on the engine side if its larger on the bore.
iceman77
Post by iceman77 »
bakaracer wrote:If you already have the 66cc kit then use that. Just make sure that the boost port on the bore is the same size on your engine case, if not you will have to match it on the engine side if its larger on the bore.
ok. thanks for the advice
iceman77
Post by iceman77 »
where would be the best place to buy the gears?
bonesv
Post by bonesv »
Try email to Steve here: http://www.vtcycles.com/ I bought 9:1's and 10:1's for $50 each +a few $ shipping. He is fast once order is received. Another source is tazland001 I think he's only got 8.44:1 right now. Daywot has most ratios also. I have bought from all of these w/good service and price.
iceman77
Post by iceman77 »
awesome. thanks again bud
Post by eliteguy50 »
x2 on those sellers. The website is not always up to date for VT though so ask about whatever parts you want even if they are not listed.
iceman77
Post by iceman77 »
eliteguy50 wrote:x2 on those sellers. The website is not always up to date for VT though so ask about whatever parts you want even if they are not listed.
I talked to vt about the gears. do you guys have any suggestions on what size rollers i should get?
Mystic
Post by Mystic »
stock or 8.5g would probably work out good for your setup
iceman77
Post by iceman77 »
Mystic wrote:stock or 8.5g would probably work out good for your setup
i thought the stock ones would be ok. but i wanted to check w/ you guys bc i knew ya'll would know
