Page 2 of 3
Re: 66cc bbk. which gears would be best for me to get
Posted: Thu Dec 22, 2011 12:30 pm
by bakaracer
Why go 66cc when you can go 72cc or 78cc for the same price if not a few more dollars and get more torque which is what you need if you live where there are hills the 72 and 78cc cylinders can still be run with the stock carb and exhaust and still get real good performance that sips gas and way less noise.
Posted: Thu Dec 22, 2011 2:54 pm
by iceman77
bakaracer wrote:Why go 66cc when you can go 72cc or 78cc for the same price if not a few more dollars and get more torque which is what you need if you live where there are hills the 72 and 78cc cylinders can still be run with the stock carb and exhaust and still get real good performance that sips gas and way less noise.
I didn't think i could still use the stock carb w/ a bigger bbk. that's why i went w/ the 66cc. live and learn i guess.
Posted: Thu Dec 22, 2011 3:05 pm
by gixxer1000chad
yeah you can use the stock carb with the bigger cc bore kits... wheelman has an interesting thread about modifying the stock carb for that reason.. in fact i think he is trying to sell one thats modded....... viewtopic.php?f=2&t=21449
Posted: Thu Dec 22, 2011 3:07 pm
by iceman77
gixxer1000chad wrote:yeah you can use the stock carb with the bigger cc bore kits... wheelman has an interesting thread about modifying the stock carb for that reason.. in fact i think he is trying to sell one thats modded....... viewtopic.php?f=2&t=21449
well dang. too late now. i got the 66cc in hand.
Posted: Thu Dec 22, 2011 3:18 pm
by iceman77
if i can get 50mph or a little better i will be happy w/ this.... for now :smile:
Posted: Thu Dec 22, 2011 3:32 pm
by bakaracer
You only need to mod the carb if your NOT using an airbox. You can still use a stock carb unmodded and airbox with the 2nd tab punched out with a bbk with stock exhaust. If your using an aftermarket exhaust,you need to run a larger carb to match the exhaust or you risk seizing.
Posted: Thu Dec 22, 2011 3:35 pm
by bakaracer
iceman77 wrote:if i can get 50mph or a little better i will be happy w/ this.... for now :smile:
If you already have the 66cc kit then use that. Just make sure that the boost port on the bore is the same size on your engine case, if not you will have to match it on the engine side if its larger on the bore.
Posted: Thu Dec 22, 2011 8:07 pm
by iceman77
bakaracer wrote:If you already have the 66cc kit then use that. Just make sure that the boost port on the bore is the same size on your engine case, if not you will have to match it on the engine side if its larger on the bore.
ok. thanks for the advice
Posted: Sat Dec 24, 2011 8:08 am
by iceman77
where would be the best place to buy the gears?
Posted: Sat Dec 24, 2011 8:31 am
by bonesv
Try email to Steve here: http://www.vtcycles.com/ I bought 9:1's and 10:1's for $50 each +a few $ shipping. He is fast once order is received. Another source is tazland001 I think he's only got 8.44:1 right now. Daywot has most ratios also. I have bought from all of these w/good service and price.
Posted: Sat Dec 24, 2011 8:50 am
by iceman77
awesome. thanks again bud
Posted: Sun Dec 25, 2011 12:52 am
by eliteguy50
x2 on those sellers. The website is not always up to date for VT though so ask about whatever parts you want even if they are not listed.
Posted: Sun Dec 25, 2011 9:56 am
by iceman77
eliteguy50 wrote:x2 on those sellers. The website is not always up to date for VT though so ask about whatever parts you want even if they are not listed.
I talked to vt about the gears. do you guys have any suggestions on what size rollers i should get?
Posted: Sun Dec 25, 2011 11:53 am
by Mystic
stock or 8.5g would probably work out good for your setup
Posted: Mon Dec 26, 2011 7:39 am
by iceman77
Mystic wrote:stock or 8.5g would probably work out good for your setup
i thought the stock ones would be ok. but i wanted to check w/ you guys bc i knew ya'll would know
