New member wants a few more MPH
Mystic
Re: New member wants a few more MPH
Post by Mystic »
heck yea bring it in the house :D i put newspaper down to soak up any oil or gas i may spill :D generally i drain all the fluids from the motor before i bring it in to work on it. the motors are really easy to take off just so you know. you could bring the motor in to work on it then bring the frame in seperately :D
Post by eliteguy50 »
Brought my tw in a motel room once. Some people carry their scooters inside and then down to the basement. That is where I had to go to get my first jog.
You could also get a big broiling pan or the rectangular oil drain pans. That way the center stand will not puncture. Through to the carpet.
WilliamK
Post by WilliamK »
Here are some pics of my progress
still needs cleaned
still needs cleaned
best pic I could get of stock airbox cover with restriction removed
airclean unres.jpg (40.01 KiB) Viewed 5739 times
with tab
with tab
airclean res.jpg (43.15 KiB) Viewed 5739 times
WilliamK
Post by WilliamK »
I think I might have some flat spots :shock:
Post by swimmingfree »
i wood like to see the other side of the verater as well as a side vue of the ramp plate..
That variator is not stock.
WilliamK
Post by WilliamK »
def not stock and its worn out...ordering a Keli from daywot when he gets back from vacation
var side.jpg (56.98 KiB) Viewed 5738 times
ramp plate.jpg (51.5 KiB) Viewed 5738 times
WilliamK
Post by WilliamK »
view of the face...doing a compression test as soon as it warms up out there
var face.jpg (71.47 KiB) Viewed 5736 times
WilliamK
Post by WilliamK »
did a compression check...35-40psi. Going to pull the cylinder and check rings...what a bummer
it cant be a minamum is 90 to 100 just to have it run ...eather you did something wrong or the tester is bad...
it cant run a 34 to 40 and run ..
Did you hold it wot?
WilliamK
Post by WilliamK »
gage setup was bad...found a leak in the hose after I pulled the jugg off...brain fart. Messured the ID= 1.535" rings have a 0.029 gap. Going to hone the jugg and install new rings. Wasn't to bad on carbon buildup...that suprised me cause my Daughter in law ran it without a muffler.
clean the ex port as well.
what was her top speed with out the pipe????????????
WilliamK
Post by WilliamK »
She said she could get it up to 30mph but she was only 110 pounds. I could only get about 23mph untill I cleaned the carb and added the new muffler.
She did quite a number on it...broken sparkplug cap...lost the airbox cover. I'm enjoying the rebuild though. I may seem dumb but I learn quick.
