My New to me 1994 Elite SR
Wow. Looks brilliant. I'm really wanting to pull off my engine and get it scrubbed down like yours there, but my main fear is getting it back on and it not running. I've learned a lot with my spree but my mechanical skills are still well below par.
1987 Spree
1994 Elite SR
1994 Elite SR
Cleaned out the carb today and wow was it filthy. Tons of sediment in it from sitting for a while. Plan to get all new lines once I have some cash flow to part with. After I got done, I took it out for a couple GPS speed runs. On flat ground, I was running into the wind at 34.3, and on the way back, was running 39.6 with the wind at my back. So I take 37mph to be a rough estimate as to top stock speed.
- ImageUploadedByTapatalk1326662601.652746.jpg (78.84 KiB) Viewed 6748 times
1987 Spree
1994 Elite SR
1994 Elite SR
Re: My New to me 1994 Elite SR
No scrubbing just 20 minutes of blasting. Mine was torn down to the bare block and media blasted with black magnum, solvent in a parts cleaner did next to nothing getting the stains off it.Carnie wrote:Wow. Looks brilliant. I'm really wanting to pull off my engine and get it scrubbed down like yours there, but my main fear is getting it back on and it not running. I've learned a lot with my spree but my mechanical skills are still well below par.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Well, went for a spin on it today to enjoy the 61┬░ weather and did AWESOME in town, but wouldn't you know it, as soon as I got two miles outside of town, my valve stem on the rear wheel decided to break. Long walk back.
Here is a picture of the last big hill before I made it back.
- ImageUploadedByTapatalk1326738456.507328.jpg (66.44 KiB) Viewed 6729 times
1987 Spree
1994 Elite SR
1994 Elite SR
Hey spree, r-y looking to steal speed like i did from the locals= lets rock
Sounds like a good time to upgrade.
Alright, just got my performance variator for my sr. Thank Eliteguy! What is a favored ramp plate for best top end performance?
1987 Spree
1994 Elite SR
1994 Elite SR
- Dio89Elite
nice find. i like the stock graphics.
i called these 'brand used'. (new to me).
keep us posted. thanks for sharing!
Running into the problem of my scoot lugging on take off. I always let it warm up before I ride but when I take off after idling a while it acts like its going to bring the front wheel IFC the ground. Then it just stops and slowly takes off until I have reached 20+ speeds for 20-30+ seconds. Them if I slow down and repeat takeoff, it accelerates without flaw. Any potential diagnosis?
1987 Spree
1994 Elite SR
1994 Elite SR
Just rolled over to 1k miles this weekend. Not twenty miles later, I had something cause a slow leak then my tire came off the rim and ended up having to buy another new tube and tire.
1987 Spree
1994 Elite SR
1994 Elite SR
I have this same year bike and everything. This scoot is insane town. Throw on a keli variator and get some 9.8 gears for it. Also a ramp plate helps with the tiny amount of lag from the keli.
The gears and variator make this bike fly so f'in fast it will make you cry in your sleep because honda stopped making them.
Got my new gears (9.8s) into the bike finally today and was overall pleased with performance. I can no longer do wheelies but my top end increased to a gps verifies 49.8 held for 13 seconds on a flat stretch with a small crosswind. Not bad for a stock bore. Achieved one mph/cc.
1987 Spree
1994 Elite SR
1994 Elite SR
Nice job on the 1 MPH/CC thing. My goal as well...
- Trafficjamz
Crap....now does this mean i need to go 125mph with my stoker setup?Wheelman-111 wrote:Greetings:
If you can get 1mph/cc.....you are doing pretty good.
I was and am rather pleased. If I upjet and put on a Uni filter, can I look for any more gain? Also, what is a good pipe for a stock bore but still can be used with bbks as well?
1987 Spree
1994 Elite SR
1994 Elite SR
