Where can i find polini or malossi exhaust pipe?
Downsouthdio
Re: Where can i find polini or malossi exhaust pipe?
Post by Downsouthdio »
That deff looks like a tecnigas exhaust
Honda super dio
Corsa
26mm
Sparrow
scottinscotty
Post by scottinscotty »
not soo much...
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
Downsouthdio
That looks kinda small for a mhr.. It looks the exact same as the tecnigas.. Bends look different to
Honda super dio
Corsa
26mm
Sparrow
Post by eliteguy50 »
I have a Tec, that is not a Tec.
bakaracer
Post by bakaracer »
Downsouthdio wrote:That looks kinda small for a mhr.. It looks the exact same as the tecnigas.. Bends look different to
Bigger doesn't mean better. Malossi designed the pipe to make power at a certain rpm and also how wide the power band will be. Pipes like malossi,polini,tecnigas and any of the euro brand pipes are usually for 50-70cc cylinders so that's why the j pipe and belly is not as big as the taiwan pipes which are for 70-90cc.keep in mind that pretty much all the pipes out there is for closed circuit racing so that reflects the design also.
dv/dt
Post by dv/dt »
bonesv wrote:Scottinscotty, I wasn't gunna do this on your thread but this keeps coming to mind:
http://www.treatland.tv/honda-dio-simon ... -black.htm
Best of luck. :D
You got me curious about that one! I wish there were more reviews for all the exhausts out there that aren't PG longs/shorts.
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
trudeau1111
Post by trudeau1111 »
you guys recommend an exhaust for Aero NB50 ? 1986 model ?
trudeau1111 wrote:you guys recommend an exhaust for Aero NB50 ? 1986 model ?
Leo Vince sp3.
trudeau1111
do they make the Leo specifically for the NB50, or does it fit from something else?
z50r-ghost
Post by z50r-ghost »
There is Leo SP3 model specifically made for the NB50. No mods to install... Just bolt it on! (and remember to re-jet & check plug...)
You can find the NB50 SP3 pipe on European scooter sites; I'm pretty sure you will have to buy the "Vision" model with angled exhaust port (The Honda "Vision" uses an NB50-type engine in Europe) -Please correct me if I'm wrong-
-jc
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
Leo Vince part number 4447.
