Page 2 of 9
Re: Getting pretty irritated.....
Posted: Mon Mar 19, 2012 9:51 pm
by bakaracer
JustynCRX wrote:I did wire the pump open, I forgot to mention that. What plugs do you recommend I use?
yeah you tied it open after it was giving you problems. you should have done that when you were putting the motor together. run a b8hs plug since your street riding. the 9 will foul at traffic lights.
Posted: Mon Mar 19, 2012 10:00 pm
by paulpauly7
Is this one of red efts bbks for the afo5e if so i think the 24mm oko will b to much carb .Did u get the kit with the heads or without if u got the 1 without the head and you are using your stock head did you get it machined 2 suit the larger piston.If not your compression is probably thru the roof
Posted: Mon Mar 19, 2012 10:03 pm
by JustynCRX
I kinda wrote it wrong when I was first typing it up, but I wired it open after I took the stock jug off. I was just wound up when I was typing that all up. But from what I'm learning even doing that doesnt offer enough oil to keep the BBK happy. I'm going to premix from now on I think. But onto the plugs again. I dont mean to sound like I'm questioning your expertise because obviously its vastly superior to mine when it comes to this stuff. but I do mostly very long distance riding, and rarely have any traffic lights on my routes. Its mostly WOT or very close to it.
I got the Malossi head with the kit.
Posted: Mon Mar 19, 2012 10:12 pm
by bakaracer
then go with the b9hs plug. keep in mind that once your in stop and go traffic, the plug will load up and possible foul out quick. try the 8 first thats a whole 2 steps colder than the plug you were using.
Posted: Mon Mar 19, 2012 10:14 pm
by JustynCRX
I have 9s coming so I'll grab some 8s and try them both. Maybe do a plug chop for both after break in. Which would be safer to use during the break in period? I would assume the 8?
Posted: Mon Mar 19, 2012 10:23 pm
by bakaracer
yeah 8. i suggest a 8 too because your in maine and i bet the humidity gets bad there. high humidity makes the bike run really rich.
Posted: Mon Mar 19, 2012 10:30 pm
by JustynCRX
Good call. I forgot how humid it gets here in the summer. What about jets for the new carb?
Posted: Mon Mar 19, 2012 10:39 pm
by bakaracer
starting jetting point 45 pilot 115 main air fuel screw 2 turns out needle clip 1 up from center. get a 42,48 pilot jet too and 108,110,112,118 main jet as the weather changes so will the jetting.
Posted: Mon Mar 19, 2012 10:43 pm
by JustynCRX
Awesome. I appreciate all the help. :worship:
Posted: Mon Mar 19, 2012 10:45 pm
by bakaracer
a 18 or 19 or 21mm carb would have been better to get. but you can get the 24 one to work. its going to eat way more gas and more noise.power and topspeed wont be any better.
Posted: Mon Mar 19, 2012 10:47 pm
by JustynCRX
Will it help out better when I add an exhaust and taller gears?
Posted: Tue Mar 20, 2012 7:53 am
by JustynCRX
I was able to get ahold of treatland and have them change my carb to a 21mm before it ships. :-)
Posted: Tue Mar 20, 2012 10:46 am
by CAPT
The reason the 24mm is suggested is because it works well and is cheap, whereas a 21mm OKO usually need to be gone though in order to run right, maybe they have fixed them, but I have yet to see one work well out of the box. Of course you could always get the spanish made 19mm.
Posted: Tue Mar 20, 2012 11:19 am
by Mystic
I have always had trouble with my 21mm it has always dumped gas out the top vent no matter how I adjust it now no matter what pilot I put in it I have to turn it all the way in to idle right and at random times it starts pouring fuel out the bottom drain. I will know for sure in a few days whether it is complete junk
Posted: Tue Mar 20, 2012 1:32 pm
by paulpauly7
I have two 21mm oko carbs on scooters and both work perfectly
