You may need to change the main again but the cht will warn you before melting it this time.WilliamK wrote:8:1 gears, #88jet and a CHT gauge...ok
Melt down...
Re: Melt down...
- swimmingfree
Re: Melt down...
that my in put but im not the best one to ask heres some thing you may want to read http://www.hondaspree.net/phpBB3/viewto ... =4&t=21022
Re: Melt down...
Ordering the BBK and Cht gauge tonight after work. going to research the final gears and order them this weekend.
I really want to keep this scooter looking and sounding stock. That is the main reasone for going with a 44mm bore (65cc).
This has been a really fun project for me. Though it's more indepth than I thought it would be.
Now the warm weather is close at hand, I need to get her back on the road QUICK!!!
Thanks for all the input and suggestions...Keep them comming
- Dio89Elite
Re: Melt down...
here's my suggestion:
keep up the awesome attitude!
we all 'live and learn'
and yeah... i've had some... uh... 'learning' experiences too.
Re: Melt down...
Research the speeds you want too. 8:1 is on the tall side for 65cc.
Re: Melt down...
ok....new 65cc BBK is on its way also ordered the CHT gauge from Trail Tech.
All I want to go is 45-50mph...not any faster...lol...not a speed demmon!!! Still tring to figure out the gear ratio thing....
Re: Melt down...
9.2 or 9.0 would be good for you. 8.7 would keep a little in reserve so you won't be winding it out for max speed.
Re: Melt down...
By the looks of the piston, you had 2 things going on, to high a compression from the melting on the edges and speckling on top the piston and to small a main jet. Not enough fuel and oil to lube ,the deep gouges on the side of the piston. The next kit run 2 head gaskets and run that 88 mainjet or jet according to what the cht is telling you.WilliamK wrote:95 SA50P
AF16E engine
Stock airfilter (Derestricted)
stock exaust (Derestricted)
plug looked good...light brown dusting even after the melt down.
Re: Melt down...
Bare with me here...there was a fair amount of research that went into the desision to purchase a 65ccBBK. I couldn't get a good compression reading on the origional cylinder 35psi was all I could get. With the new kit I also bought a new compression tester, threaded type. After installed and ran for a few minutes I took another compression test...75psi WOT. Thought for sure I had a bad tester. Tried it again just before I pulled the jugg off and it was 50psi...
I'm sure the tester is wrong.
I want to keep this thread open for any input people can think of....also I have removed the oil pump and installed a plug. Should I reinstall the pump???
Re: Melt down...
Did you continue to kick until the needle stopped? It can take several kicks for the pressue in the line to even out.
Re: Melt down...
Shure did....I want to try to do a static test on a pressure tank or something. I think the gauge is bad
- swimmingfree
Re: Melt down...
auto zone rents then and sell them as well.. dont no were your getting them from but i wood not get another from there...
Re: Melt down...
Ebay special. Looked like a good kit but right now, I can't trust it. Going to test it out this weekend and see how far its off. It seems to hold pressure but the hose might have a leak or not have a proper seal.
BBK shipped this morning and should be here middle of the week. Not sure how long it will be for the CHT gauge from Trail Tec. I hope its a good one. Don't wanna spend big bucks for an acft style gauge.
Final drive gears will have to wait a bit for more funds. Going to reinstall my #88 jet and maybe redrill the old jet to around #95.
- swimmingfree
Re: Melt down...
95 is going to be way to big if your running the stock air box..WilliamK wrote:Going to reinstall my #88 jet and maybe redrill the old jet to around #95.
- tazland001
Re: Melt down...
Use a 90-95 main with a free flow filter and break the d a m n thing in very slow. Break in is very important as well.
What was the compression after install??
taz
taz
