'85 honda upgrades?
Re: '85 honda upgrades?
Compression test is next and some Seafoam in the gas tank. Also, when was the last time you changed the spark plug? Scooters that slow down have something wrong and hot rodding sick motor is a waste of time and money.
Post by swimmingfree »
bear is telling you the truth...
one other thing you may try is a bigger tire a 3-10 i think will fit if you grind on the case a little.. it give you 3.142in more per turn .. one the to thing about is the more you get on top end the more you will lose on take off.. that most of us do a motor swap..
abreen89
Post by abreen89 »
compression is good, spark plug is new, brand new tope end i have 3 tanks of premix through it, and heat cycled it 100 times.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
compression is good.... like 100 or 2000 number tell a lot!!!!
Last time a guy told me compression was good, it was 24 PSI below spec when he actually checked it.
abreen89
Post by abreen89 »
spark plug is a number 18 on the plug chart from wikispreedia. after i did a plug chop at WOT (25mph)
compression is at 105 psi tested it 3 times
it shuts off at WOT so i think this bike needs to go back to the Not running/needs work section of the blog =( ......
Then we can focus on performance!
viewtopic.php?f=3&t=22467
Bossshelby
Post by Bossshelby »
I cut the muffler open and modified it and i got 25-26
Have 4, 84-86 Sprees
Sprite-85 Honda spree
-87 elite 50 engine
-90 jet
-9 and 10 gram rollers
-Highly ported intake and exhaust
-custom performance muffler
3 original sprees. A red, black and white
