Interesting problem with throttle
Farfignugin
Post by Farfignugin »
So, on the thermal thing, there is an arrow, where and what way is it supposed to go? at the moment it is towards the side pannel pointing away from
the carb, is that correct?
mopedman
Post by mopedman »
i dk, i never realy looked at one of those up close
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
berreta22
Post by berreta22 »
you will know if its on right by looking at the edges of it...it should be flush (even) all the way around with the intake...if this was installed backwards the bottom edge of the brown part would stick out...you cant really miss it
Farfignugin
I have found problem and made new topic w/ proper subject: Fuel flow problem (in carb), but then even that isnt correct, dang. It should be Vaccume problem
