did you try gutting the other expipe and putting a bigger tipp on it ????
thank you kingkamehameha ive never seen this ... and your a grate dog for diggen this up thank you ...
handicap (dyslexia) looking for
swimmingfree wrote:did you try gutting the other expipe and putting a bigger tipp on it ????
i haven't only because i'm not sure where the restriction is in the Iowa pipe that i have. there's no washer visible, but when i changed the pipe out for a non-Iowa pipe it was clear there's something not visible that held it back
Downsouthdio wrote:No prob bro.. What bbk do you have? Moped hospital sells the 66cc airsal aluminum kit. Pretty decent price too
i have the taz kit. idk who makes it for him other than the piston being an RIK
'80 Puch Magnum MKII
'78 PA50 Hobbit
dose the head pipe look the same on the 2 pipe ??? if so then it wood have to be in side of it mufler i wood think??
You guys have been here for how long and you have never bothered to look through the advanced tech docs? There is so much info on this site all you have to do is use the search feature and browse through the old tech docs. Jennings is two stroke jesus man read up
no one have ever said im the smart one on here and if thay did thay lyed to you
