Page 2 of 11
Re: Sym dd50 build!!
Posted: Mon Apr 09, 2012 1:35 pm
by tabs808
It doesnt matter if you dont have any problems with it now, trust me, just swap it out.
If your gonna insgall new bearings and seals, you might as well install a new crank, port match the boost port, and open up the intake port. Stock intake port on dd50 block is smaller than stock af16 intake port.
Sym dd50 build!!
Posted: Mon Apr 09, 2012 10:45 pm
by Madman
I'm defiantly going to port it otherwise no point to crack the crank case!!
Sym dd50 build!!
Posted: Tue Apr 10, 2012 6:48 am
by Madman
Got one of these on the way, with a stronger connecting rod for bbk!
Still waiting on:
75cc bbk
Crank bearings, top end bearing
Crank seals
Oil pump plug
Crank puller, bearing puller, flywheel puller,
New fan
New drive belt
It will be a new engine when I'm finished all that will remain is the crankcase!
Posted: Tue Apr 10, 2012 3:27 pm
by paulpauly7
is that from yahoo auctions?
how much?
mini stroker?
Sym dd50 build!!
Posted: Wed Apr 11, 2012 12:22 am
by Madman
It's from Taiwan and I found it on alibaba.com It's not a mini stroker it's a regular 41.4 stroke
It is about 60$us delivered, they have a stroker for about 100$ delivered but I don't know if it would match the port timing on the bbk I baught so I'm gonna go stock.
Sym dd50 build!!
Posted: Wed Apr 11, 2012 11:51 am
by Madman
Got that ordered and was reading a thread about a nice build by burnt toast and was wondering. I have a OKO28mm carb already, Baught it and never used it!
Would I be able to use it on this build or would it be too big?
I currently have a 21mm OKO
I'm going to port its intake and boost to match the bbk which is better!
Don't say 24mm cause I haven't got one?
Which is better?
Sym dd50 build!!
Posted: Thu Apr 12, 2012 2:50 am
by Madman
Parts started arriving today!!
Fan top end bearing and crank seals.
Posted: Sat Apr 14, 2012 6:27 am
by tabs808
Is that another stock dd50 crank that you bought? You shoulda jist got a stock af16 one. Or a stock full counter. Ive had bad experiences with stock dd cranks, where the two halves loosen up and con rod falls out or the crank breaks right by the crank seal on the pulley side.
If you have the 28mm oko, it should be good already. Youre porting the block anyways, just jet it correctly and you should be safe.
Posted: Sat Apr 14, 2012 10:01 am
by evilone
Madman wrote:I have a OKO28mm carb already.
I currently have a 21mm OKO.
Use the 21mm.
Sym dd50 build!!
Posted: Sat Apr 14, 2012 8:07 pm
by Madman
It's not the stock crank it's designed for tuned engines. Just the same stroke.
Ok that's 1 for 28mm
And 1for 21mm
Posted: Sat Apr 14, 2012 11:57 pm
by Downsouthdio
21 is reAl simple to tune.. 28 will make more power up top.. Jus a lil
Posted: Sat Apr 14, 2012 11:58 pm
by Downsouthdio
I say 21
Sym dd50 build!!
Posted: Sun Apr 15, 2012 2:48 am
by Madman
Thats 2 for 21mm
1for 28mm
Posted: Sun Apr 15, 2012 2:51 am
by paulpauly7
id say 21 better for inner city traffic and easyer to tune the 28 if your a highway runner
Sym dd50 build!!
Posted: Sun Apr 15, 2012 3:51 am
by Madman
Well I drive in the city! Tokyo!! And scoots are not allowed on the highway here so that = 21mm
