Page 2 of 4
Re: Ultimate Tool Box for a Honda scooter.
Posted: Wed Apr 11, 2012 1:25 am
motormike wrote:...philipps...
what about this one ??...phillips
Posted: Wed Apr 11, 2012 1:30 am
by Trafficjamz
did your spellcheck checkout tonight?
Posted: Wed Apr 11, 2012 1:34 am
by Trafficjamz
Bearing separator
this tool is great when the bearing gets stuck on the crank
Posted: Wed Apr 11, 2012 2:00 am
deuce217 wrote:Makita impact with 1/4'' and 3/8'' adapters to fit your sockets. THIS SAVES TONS OF TIME!
For disassembly ONLY, using on assembly will screw something up for sure.
Posted: Wed Apr 11, 2012 2:46 am
by Ewestfall
Trafficjamz wrote:Oh tire spoons
I learned something today.
I have this tool for changing tires.
Please direct me to this tool please I have found the spoons and was looking at
Powerlift Tire Changer PTC
Powerlift Tire Changer : Tire Changer, BIG BUCKS OFF! Both strong all-steel construction. This will mount and dismount a full range of tires, from 8" to light truck. Get yours now! AVAILABLE SEPARATELY: Tire Changer Attachment for Motorcycle Tires - word search in our Store for 'Tire Changer'. « less
Posted: Wed Apr 11, 2012 7:11 am
by fastplastic
Does this have something to do with the possible new scooter work shop thats a lil closer to home?
Posted: Wed Apr 11, 2012 8:16 am
by swimmingfree
is this tool thing for on the road or at the house ??? because it wood be nice to have a 39mm at home but some thing you wood not need on the road...
i see how thing are , all bad spelling is because you no me and you cout a case of dyslexia from me lol
Posted: Wed Apr 11, 2012 8:22 am
by eliteguy50
45mm too.
Posted: Wed Apr 11, 2012 9:31 pm
by Trafficjamz
fastplastic wrote:Does this have something to do with the possible new scooter work shop thats a lil closer to home?
Trafficjamz is getting split in to two sides
car audio side
and scooter repair on the other
Need to know what tools to stock in the scooter side.
Posted: Wed Apr 11, 2012 9:49 pm
by eliteguy50
Universal pulley holders
Snap ring pliers
Something to cut hoses
Electrical equipment: testers, meter, stripper, crimper, fuses, electrical tape...
Battery charger
Air compressor and tire gauge
Spare hardware
Thread chasers
Penetrating oil
Cleaning brushes and wire for carb cleaning.
7mm for removing restrictor and grease plates
Bearing puller for transmission case bearings and wheel bearings
Posted: Wed Apr 11, 2012 9:51 pm
by eliteguy50
A basic set of standard sockets. Several of my bikes have had standard nuts forced onto metric studs.
Marker for variator tuning.
Measuring device to spec belts and bearings. Syringe for transmission oil. 4mm wrench. Pliers or spring pullers.
Posted: Wed Apr 11, 2012 11:38 pm
All good ideas, and will compile for the 'wiki.
A box of disposable gloves used from the start makes lunch go better :D
Digital camera for is handy for what things should look like when put back together - hoses, wires etc...
Test lamp (DMM even better), soldering iron, hot air gun, heatshrink, jumper leads are favorites for electrical repairs.
A parts substitution kit of known good CDI, coil are very much timesaving to rule out parts before digging into the stator....
Guys with big presses for gear swaps are of envy.
Favorite rust buster solvent, carb cleaner, Ultrasonic cleaner.
Most expensive, but well paid back in repairs have been -- O/A torch, and arc welder. They are handy on the repair side for stuck/broken bolts as well as exhaust, basket/rack repairs and new fabrication.
Posted: Thu Apr 12, 2012 12:09 am
by indetrucks
39mm socket
Torque wrench
Service Manual
2 stroke oil
spare bulbs
Posted: Thu Apr 12, 2012 12:13 am
by wentwest
Magnetic parts bowl;
Good camping head light;
piece of foam to kneel on;
6 pack of cold beer;
radio
Posted: Thu Apr 12, 2012 12:15 am
wentwest wrote:Magnetic parts bowl;
radio
If you are working on someone else's scooter the beer is real stupid.
