spree+jazz= spazz!
Fishman43
Re: spree+jazz= spazz!
Post by Fishman43 »
Looks like it will be a kick in the pants to ride! Literally and figuratively :coolcruise:
Post by swimmingfree »
nice job looks good :happy: .....
but im a 2 stroke fan and i like shock as well ..
swimmingfree wrote:nice job looks good :happy: .....
At least he has a two stroke exhaust. :lol:
spazz
Post by spazz »
I had to install a coolant tank. so I ordered the "Weapon R" tank the construction is solid,and it is smaller than the password jdm one. man there is no room under these tiny panels...
I needed a bracket. so I started with some recycled square stock.
now it is an "L" bracket.
I am using nutserts to install the bracket. they expand in the frame and leave a threaded hole.. they look like this.
spazz
Post by spazz »
here is a photo with one installed. and the hole for the other one.
and here it is fully installed ,one step at a time you know. I painted the bracket orange with "Montana gold, 61250 terra" that paint is awesome by the way...also it is held on with a "sickspeed" washer bolt combo.
the red squares are stickers.
Fishman43
Post by Fishman43 »
Is that a standard pop rivet tool? If so I want to find these so called nutcerts, that seems like a handy addition to my seldom used rivit gun!
spazz
Post by spazz »
Fishman43....look closely at the tool...it has a threaded end sorry bro, this will not work with a regular rivet gun.
I am doing small carbon accents on this build. so here is my fork wrapped.. these are done now and look OMAZING in the sun.
Fishman43
Post by Fishman43 »
My failing eyes and modestly blurry photo led me down the path of hope...
spazz
Post by spazz »
I made this tail light bracket and wrapped it in carbon vinyl. the taillight was like 20 bucks, the panels fit better when they are bolted down.
NZHonda
Post by NZHonda »
We use this setup on aircraft. It is called a RIVNUT Tool. It has a threaded end that srews into the nut, then you insert that into the hole and squeeze it up like a 'pop rivet', unscrew the tool and hey presto your done. A quick google search reveals a few options.
Honda DJ1R project
Dr_Craw
Post by Dr_Craw »
as sexy in real life as in pictures!
Roll the dice
ped
Post by ped »
Hi spazz. very nice build. the spree looks very cool. :thumbwink:
deuce217
Post by deuce217 »
Lovin it! I wonder what that sounds like? You should post a video of that thing.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
spazz
Post by spazz »
Spazz here. this project is on hold but I learned alot since i started this endeavor,,,,,
birdman
Post by birdman »
...and whats that?
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
