Are you able to tell us what brand of bore you are using? Taiwan products are generally very high quality, and I've never had any quality issues. My Ruima 50mm BBK was perfectly set up right out of the box and has run without a hitch, nearly always WOT, for almost 10,000 miles. But I'd sure like to know if there's any low-quality merchandise out there, and who the maker is. I'm sure others here would like to know, too. Thanks!evilone wrote:Just a F.Y.I for anyone planning on running a 50mm Taiwan bore.
50mm taiwan bore info
Re: 50mm taiwan bore info
Here is a picture before it was broken. But I don't think mine was too bad I think I broke it!!
- ImageUploadedByTapatalk1336727614.623884.jpg (63.67 KiB) Viewed 5383 times
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
bakaracer wrote:You have to check with a feeler gauge to make sure what the gap is at. But just by looking from your pic ,that looks like its more than enough. My guess is .013
We use mm here so it is 0.2mm
Converted to inches that is 0.0079
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
And piston clearance was 0.15mm or0.0059 inches if I'm measuring right!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sorry , got it used so i do not know the brand.JJ Joseph wrote:Are you able to tell us what brand of bore you are using?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- paulpauly7
the brand that madman has is MTRT i have the same kit sitting on my bench new in the box
yeah thats a bit tight. you want more like .20mm or.23mm range.Madman wrote:And piston clearance was 0.15mm or0.0059 inches if I'm measuring right!
JJ, i contacted previous owner about what brand the bore is...it is a Ruima.JJ Joseph wrote:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
bakaracer wrote:yeah thats a bit tight. you want more like .20mm or.23mm range.Madman wrote:And piston clearance was 0.15mm or0.0059 inches if I'm measuring right!
So when I hone it out and add a new piston it should be fine I guess.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
(not too bad)evilone wrote:piston to cylinder clearance was .002" (not too bad).
After more inspection and actually thinking about the measurements i got, i see mine is tight!
madman...mine is about .102mm-.152mm (.004"-.006"), and that's after honing the cylinder.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone wrote:(not too bad)evilone wrote:piston to cylinder clearance was .002" (not too bad).![]()
Yeah ok its good (or bad) to know that this is one thing that could be messing us up, I guess a good bit of honeing could bring this clearance back to within specs. But i have a new 50 mm piston on its way and it will be interesting to see the clearance with that piston! Is the bore tight or is the piston fat?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
I've been second guessing myself all day at work....bakaracer, why does it need to be .20mm - .23mm range?bakaracer wrote:yeah thats a bit tight. you want more like .20mm or.23mm range.
That would be .008" to .009" when typically they are around .002" to .004"
That would mean madmans piston to cylinder wall clearance would be a little under .006" which is actually a little on the big side. Is it a Ruima thing or what?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
You can try it at .18mm if you want. Pretty much any cast iron taiwan bores are tight. That's why you hear a lot of guys seizing a new bore with not that many miles on it. Its a crap shoot that you will get one that's. Ok clearance wise and no issues. But majority of them are tight by about .0015 so a quick hone helps. Plus pretty much all the cast iron bore don't have chamfered ports so running a flex hone throught will massage the ports too so they don't act like a squeegee and scrap the oil off the piston. Those sharp edges on the ports can chip small pieces off and cause seizes too so running the flex hone eliminates that issue of happening. Brake hones only make those edges on ports even sharper or even chip them so don't use a brake hone also called stone hones.
- Red Eft Performance
First off Evilone how are you getting your measurement? Are you measuring the same way madman is in the pic above?evilone wrote:I've been second guessing myself all day at work....bakaracer, why does it need to be .20mm - .23mm range?bakaracer wrote:yeah thats a bit tight. you want more like .20mm or.23mm range.
You guys should be measuring at the bottom of the piston 90 degrees out from the piston pin on the skirt. That is typically the largest point on the piston. Its very hard to get a accurate measurement with a feeler gauge. Really not the best way to do this.
Baka would know better than I what the best clearances would be for these bores.
So with that said if you are measuring with a feeler gauge you have to take your measurement and Divide it by 2. cause you are pushing one side of the piston against the cylinder wall and you are actually measuring the gap of both sides. So if you take Bakas suggestion of .008" your clearance is actually .004"
I will admit .004" seems a bit big for a 50mm bore. But maybe thats what needed do to the low quality of these bores. Again Baka has alot of experience with this stuff.
Red Eft Performance
View products click => Here
Thanks Keith! yes the measurement should be taken at the piston pin area or just below it. the top of the piston is smaller than the middle and skirt area as the piston is tappered.
