Page 2 of 2
Re: runs like crap...what am i missing?
Posted: Mon May 14, 2012 1:53 am
by Trafficjamz
evilone wrote:Trafficjamz wrote:a bad cdi caused me months of grief last summer.
1 point for trafficjamz. Replaced cdi with an extra i had and it ran a lot better. It went down the road so now i can tune the carburetor
I will be dropping to a 21mm or 24mm when i have the extra $$
What am I gonna do with all these extra points?
failing cdi's are hard to troubleshoot.........I'm glad you got it sorted out.
Posted: Sun May 20, 2012 6:02 am
by tabs808
Mine did this week one was cdi, a week after i fixed that, it was my coil, week after that was base gasket leak, week after that was head gasket leak, week after that was bad plug, week after that was messed up needle. No joke. Then it ran good after those couple weeks. Glad you found out your problem.
Posted: Sun May 20, 2012 10:15 am
by evilone
Bear45-70 wrote:I would also suspect your idle mixture screw is too lean as well as you pilot jet.
Yes, the 55 pilot is too lean. The 58 pilot is better, it runs best with idle mixture screw about 1 3/4 out using the 58.
Posted: Sun May 20, 2012 10:23 am
by evilone
This thread can be put on hold. I was trying to tune the carb when i really have a bigger issue. When bigger issue is taken care of i think tuning the carb will be a breaze.
