Page 2 of 2
Posted: Fri May 19, 2006 8:17 am
by MySpree
i just put the engine back in the elite today. it started up and made a lound rattaling noise so i re took it apart put it together again and it still sucked so i tryed to rattle whatever it was off, so i rode offroad, and now it doesnt make rattling noses no more. and now i have a faster top speed. maby my exaust was clogged
Posted: Fri May 19, 2006 6:13 pm
by darat
man o man i cant wait untill he blows that thing up... he just cant leave anything alone..
Posted: Fri May 19, 2006 10:29 pm
by maddog
you can hit 55 mph on a elite-s with a basic derestriction and 9 to 1 gears on level roads and no wind and if you weigh 160lbs. you can also change the rear clutch pulley to a dio, shave the high spots on the case to clear the belt and gain more top end, i have a used set of gears for $15 plus shipping. BTW make sure you do it all at the same time or you mess up the engine.
Posted: Sat May 20, 2006 10:23 am
by MySpree
ill take it.
and no i found what it was. i had some of the shaviengs fron when i tok the restrictor out in my exaust.... so madddog were do i get this pully where do i send money to for the gears?
Posted: Sat May 20, 2006 11:04 am
by hrnytrtlsgsxr
maddog wrote:you can hit 55 mph on a elite-s with a basic derestriction and 9 to 1 gears on level roads and no wind and if you weigh 160lbs. you can also change the rear clutch pulley to a dio, shave the high spots on the case to clear the belt and gain more top end, i have a used set of gears for $15 plus shipping. BTW make sure you do it all at the same time or you mess up the engine.
you either have the stock dio trans which is in every dio motor or the zx trans. the s stock trans is not different from a dio trans. They are the same. it's the ZX trans that is different.
Posted: Sat May 20, 2006 11:06 am
by hrnytrtlsgsxr
BTW happy and dave toba who is the 1/8 record holder in hawaii besides many a kickarse peds in hawaii does not believe in the zx trans either. He does not use it in his peds.
Posted: Sun May 21, 2006 3:32 pm
by MySpree
madddog i want the gears!!!!!!!!!
Posted: Sun May 21, 2006 4:19 pm
by darat
haha u cant have them...
Posted: Sun May 21, 2006 6:10 pm
by MySpree
why cant i have them! im gonna get them.
Posted: Sun May 21, 2006 11:29 pm
by drl33t
but what makes the dio so great, what makes it work beter that all the rest???
Posted: Sun May 21, 2006 11:34 pm
by bitteraspects
well crafted, higly modifiable motor. tuneable transmission, and TONS of mods readily available.
Posted: Mon May 22, 2006 8:30 am
by MySpree
thousands of bolt ons. and its a honda
Posted: Tue May 23, 2006 9:45 pm
by drl33t
yea, the honda part r0x0rz... so how easy is it to get one of theas dio setups? are they inexpencive?
Posted: Wed May 24, 2006 7:49 am
by darat
HONDA KEY WORD
