Did they make a black Elite 50 SR in 2001?
deuce217
Re: Did they make a black Elite 50 SR in 2001?
Post by deuce217 »
sanjuro wrote:Nice collection. If you're collecting you might as well try to get some JDM dios with disc brakes.
I will when I see one. I have yet to see one in my area. How much do they sell for usually in good shape? I need disc brakes!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
sanjuro
Post by sanjuro »
You can usually find them in Vancouver on CL. They are pretty cheap there ($500-1500), but mostly bare bones versions.
My thread has a bunch of pics.
deuce217
Post by deuce217 »
sanjuro wrote:You can usually find them in Vancouver on CL. They are pretty cheap there ($500-1500), but mostly bare bones versions.
does the dio use the same BBK kits, and gears as the AF16?
50mm BBK (tai)
V-8 pipe
sanjuro
Post by sanjuro »
Anything aftermarket that was made for the AF18 motor can be used on the AF16 motor except the stator since the AF18 has the pulse generator at the front of the right engine case instead of behind it.
Here's the major differences:
http://www.hondaspree.net/phpBB3/viewto ... =5&t=21871
deuce217
Post by deuce217 »
sanjuro wrote:Anything aftermarket that was made for the AF18 motor can be used on the AF16 motor except the stator since the AF18 has the pulse generator at the front of the right engine case instead of behind it.
Nice write up! Thanks. I noticed all my elite SR stock exhausts say goshi also. Is this standard?
50mm BBK (tai)
V-8 pipe
bakaracer
Post by bakaracer »
yup!
deuce217
Post by deuce217 »
yup!
Baka-
I think I might do a MHR 72cc with MHR Stuffer for my black elite. What RPM does your make the most power? Which variator do you think is the best for the dollar. I have 2 prodigy's now. But I dont have anything to compare them to.
50mm BBK (tai)
V-8 pipe
OneBulletDan
Post by OneBulletDan »
arnada wrote:nice, i think its more like a collection, not greed. all u need now is a yellow one. is there any other color?
They made a "Carbon Grey" in 2000, too.
sanjuro
Post by sanjuro »
There's nothing wrong with having backup scooters:-)
