The long hose and adapter subtract PSI, not add.Madman wrote:bakaracer wrote:check for a air leak and make sure the compression is 125. use the kick lever and not the electric start to check that. also make sure your not using a long hose and a adapter for the compression tester. it adds volume to the head so compression readings will be lower
How many psi do you think the hose and adaptor adds?
need help on jetting start point.
Re: need help on jetting start point.
- Trafficjamz
The v8 pipe on my 50mm ministroke build always kept the temps down compared to my chamber pipe.guen84 wrote:PG LongTrafficjamz wrote:what pipe?
what did the v8 rev to? i dont understand how a pipe can make you run cooler without loosing performanceTrafficjamz wrote:The v8 pipe on my 50mm ministroke build always kept the temps down compared to my chamber pipe.guen84 wrote:PG LongTrafficjamz wrote:what pipe?
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
- scottinscotty
I would think the more the flow the hotter it will run!
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
I would think the opposite would be true. More hot air out and more cooler air in will cool things down.
the v8 doesnt rpm as much as the pg long does so the engine doesnt run as hot due to that. less rpm,less flow through the motor, less compression in the case and head.
- Trafficjamz
guen84 wrote:what did the v8 rev to? i dont understand how a pipe can make you run cooler without loosing performanceTrafficjamz wrote:The v8 pipe on my 50mm ministroke build always kept the temps down compared to my chamber pipe.guen84 wrote:
PG Long
The v8 pipe does not rev as high.....however it makes more power at lower rpms than a pg long or chamber pipe.
less rpms = less heat
- scottinscotty
if you run it too rich will that cause it to run hot? or maybe too much oil? i know too much oil will cause it to bog down at higher rpms?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
- Trafficjamz
scottinscotty wrote:if you run it too rich will that cause it to run hot? or maybe too much oil? i know too much oil will cause it to bog down at higher rpms?
running rich does not cause high temps.
running rich lower temps and power.
running too much oil will cause your air / fuel raito to become lean, and therefore run hotter.
