AF05E Malossi 47 mm BBK installed
tlthehun
Re: AF05E Malossi 47 mm BBK installed
Post by tlthehun »
Malossi 47 mm BBK part number on the box = 31 6405
matching Malossi cylinder head = 38 7157
tlthehun
Post by tlthehun »
Switched to 32:1 Chevron 89 octane + Redline Two Stroke Race after two or three tanks of 50:1 mix.
My first impression was that the idle was better, less responsive and powerful off the bottom and some surging at part throttle on deceleration but after a weekend of use I'm either used to it or it just isn't that noticeable.
Happy for the extra oil and seemingly adequate fuel as laughably THREE different police officers at and around Laguna Seca kept directing me and my 40-something mph scooter towards highway after which I unavoidably ended up on a FREEWAY low on fuel, sun setting and no practical choice other than continuing on. SA50 was pinned for at least 15 minutes riding on the shoulder at sea level and 60 degrees F.
Time to carry pre-measured 2T oil and maybe convert the oil tank to a fuel tank.
JJ Joseph
Post by JJ Joseph »
tlthehun wrote:Time to carry pre-measured 2T oil and maybe convert the oil tank to a fuel tank.
Don't remove your oil pump! It's a useful piece of machinery and increases the reliability of your 2-stroker. The Honda oil pump can easily handle a 100cc BBK. Running without the oil pump is like going back in time to the 1940s. The only time you should be running premix is if you're turning 12,000+RPM, when you should be running a richer oil mixture than stock (2-strokes need more oil at high RPMs). But a 9,000RPM BBK mod, driven in daily traffic, should keep the stock oil pump for reliability.
1slow8t
Post by 1slow8t »
JJ Joseph wrote:a 9,000RPM BBK mod, driven in daily traffic, should keep the stock oil pump for reliability.
Would anyone care to second this? I'm curious as to whether it is necessary for all this additional work for the break in with the Malossi BBK. Would using the stock fuel/oil setup be a no no? (with the exception of the jet)
Downsouthdio
Post by Downsouthdio »
Do not listen to that..pre mix your gas.
Honda super dio
Corsa
26mm
Sparrow
paulpauly7
Post by paulpauly7 »
correct dont listen to jj
welder steve
Post by welder steve »
Also the stock pump is made to oil a certain displacment (sc) so dont use it, or do and run a weak premix in the tank
tlthehun
Post by tlthehun »
It's been over a year and about 800 mostly wide open throttle miles since I installed the BBK.
I had my first problem recently, which turned out to be broken reed petal on the Malossi carbon fiber reed that was supplied with the BBK.
2013 07 12 2051 SA50 reed.jpg (55.32 KiB) Viewed 9072 times
"Funny" that I held that part in my hand when it was new out of the box, thinking, "I don't really need this", questioning its durability.
Safe to conclude that when your air filter is saturated with gasoline, your reed has failed but I went ahead and did a leakdown test before I removed the reed block.
Back to the stock Honda reed petal and we're good as new, although I don't EDIT: do want to try to find a Boyesen dual stage reed, which were always good to me in my dirt bike days.
While I was at it, I fitted a new spark plug.
I've been running 50:1 89 octane and Redline Two Stroke Race for as long as I can remember, bolstered by Honda recommending 40-50:1 for the much more powerful and higher revving NSR50R engine, better throttle response and knowing that the engine is getting more gasoline this way for a richer mixture.
tlthehun
Post by tlthehun »
On the oil pump.
If you don't get it without an explanation, you won't get it with one.
tlthehun
Post by tlthehun »
Update.
The fun and games lasted till 2014-01-14 (5272.4 odometer) when something let go in the bottom end.
I procrastinated badly, err, prioritized with an endless list of other tasks that need my attention and $ but I finally split the cases today.
I'll start searching this site but recommendations for a replacement crank would be much appreciated, seems to no longer be available from Honda.
Peteyparado
Post by Peteyparado »
Good excuse to by a stroker crank??
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Is that a stock AF05 crankshaft? Bearing seized?
Peteyparado
I have a stock af05e crank if u looking for 1
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
tlthehun
Post by tlthehun »
Wheelman-111 wrote:Greetings:
engine number: AF05E3303235 so yes?
Bearing's fine, at least not spun in case and spins okay.
tlthehun
Post by tlthehun »
Peteyparado wrote:I have a stock af05e crank if u looking for 1
New? I'm probably going to stay away from used if I can help it. I've barely searched, seems that Athena might have a stock replacement crank, model names are confusing, I haven't dug deeper.
