Page 2 of 2
Re: 2001 Honda Elite Sr
Posted: Wed Jun 20, 2012 1:50 pm
by Dylan2001Elite
is there anything on it that i can just tune to make it more zippy, its at a point where its not fast and not able to wheelie much
Posted: Wed Jun 20, 2012 2:08 pm
by eliteguy50
Dylan2001Elite wrote:is there anything on it that i can just tune to make it more zippy, its at a point where its not fast and not able to wheelie much
With your lean issue, you won't have any top end and won't have near the full power from the engine. You should check the exhaust too. It probably matches the jet as a "p" model.
Posted: Fri Jun 22, 2012 10:40 am
by Dylan2001Elite
i may need to start replacing crap, including throttle body
Posted: Fri Jun 22, 2012 11:06 am
by eliteguy50
Dylan2001Elite wrote:i may need to start replacing crap, including throttle body
Are you referring to the carb and slide assembly?
Posted: Sat Jun 23, 2012 8:46 am
by Dylan2001Elite
yeah the whole cable though
Posted: Sat Jun 23, 2012 9:00 am
by Dylan2001Elite
and i like bleed vegy oil down the start of my throttle cable?? either by air compressor or my mouth
Posted: Sat Jun 23, 2012 9:28 am
by evilone
Dylan2001Elite wrote:and i like bleed vegy oil down the start of my throttle cable?? either by air compressor or my mouth
I'm confused, where did that come from?
Posted: Sat Jun 23, 2012 9:50 am
by Dylan2001Elite
oops sorry forgot to mention whats wrong with throttle, it use to only stick at wide open, now it sticks just about everytime the throttle is twisted, i disconnected the main cable and the splited cables, and its in the first half, it is getting caught somewhere and im thinking lube 'er up lol
Posted: Sat Jun 23, 2012 10:18 am
by eliteguy50
Clean up your handlebar. The plastic throttle tube can catch on that if some dirt or rust is in there.
Posted: Sat Jun 23, 2012 10:43 am
by Dylan2001Elite
eliteguy50 wrote:Clean up your handlebar. The plastic throttle tube can catch on that if some dirt or rust is in there.
when it gets stuck, i can twist the throttle forward but it kinda spring to wide open, and if the cables are all hooked up, i can push the oil pump thing to idleing position i can feel the cable come unjammed
Posted: Mon Jul 09, 2012 4:54 pm
by steffen707
lol, for safety sake, while doing wheelies with your dumpster found elite SR, I would replace your throttle cable first with your $50. Next clean the carb and check the air filter, then check the belt and rollers and make sure those are good.
As they usually say on this forum, you gotta make sure its running well in "stock form" before you try modifying it. With the remaining money buy yourself a bicycle helmet, because you won't be able to afford a motorcycle helmet, but at least something to hold your skull together when you wipe out from a wheelie.
Posted: Mon Jul 09, 2012 5:10 pm
by Dio89Elite
IMO lighter weights and/or stiffer center springs would help.
Try it with just lighter weights first.
If you're going to try to salvage your throttle cable, get some decent lubricant like 3-in-one oil.
It doesn't cost that much less than $3; save the veggie oil for cooking.
Otherwise, if the throttle cable isn't working, buy one. You need to have a throttle cable that works well. ;)[/img]
Posted: Thu Jul 12, 2012 12:04 am
by Dylan2001Elite
i snowmobile and already have a helmet, i fixed the throttle by * riggin it with a thumb throttle, i modded the intake a slight bit and dought it will need jetting, now removed front brake lever, will i need that?
Posted: Thu Jul 12, 2012 12:13 am
by Dylan2001Elite
i will also spend 100 dollars now, gotta love having a job when ur 14! no expenses! i went threw it all btw, i would like to upgrade carburator maybe? would that be noticeable increase?
