Rpm drops with speed increase.
Re: Rpm drops with speed increase.
50 is slow for 8.4 gears
Draw on the variator with a sharpie marker to see how far your belt is shifting up the pulley.
judging rpm by ear is not always the best way. :wink:
Re: Re: Rpm drops with speed increase.
graphite9 wrote: maybe the 82cc Taiwan bore just sucks.
Sent from my DROID RAZR using Tapatalk 2
Maybe.....but then how do you explain this 82cc. :smile:
Quoth ScootinScotty's Cousin:
i agree, and disagree... only due to the fact that when you max out your variator and the clutch is too hard to open it will strain your engine and cause the rpm's to lower with the strain of the clutch.. my cousin had this same issue... the scooter was a rocket, up untill the variator maxed out and his 3000 center spring caused to much strain on the engine to allow it to go anyfaster
With all due respect, your cousin simply misdiagnosed his issue.
The rear pulley is Not the "clutch". It is referred to as the Driven Pulley or Driven Face. The clutch is the thingy under the bell.
The stiffness of the Center Spring can NOT "strain the engine". It can move the belt more quickly back into a lower "gear" position, and thereby raise RPM. The engine never knows what's going on downstream... With the throttle open, it'll spin up to the RPM balance point dictated by the rollers and the center spring.
I'm all for free exchange if information and opinions on the Forum, but the following is not a matter of opinion, but of Fact:
All things staying equal,
Stronger Center Spring = Higher RPM
Weaker (Or WORN-OUT) Center Spring = Lower RPM.
Heavier Vario Rollers = Lower RPM
Lighter Vario Rollers = Higher RPM.
When misinformed people like your cousin post nonsensical information on the Forum, it can frighten, confuse and anger the Newbs. Please refrain.
Mystic
Post by Mystic »
is that the first time you checked compression?
I really think this is a trans issue not an engine issue.
I don't understand when you say you can smoke your friends 72cc's, but yours is not fast enough?
are you sure about the gear ratio? You should count it by hand.(turn the wheel once count the number of bell turns)
A worn center spring of too heavy rollers are usually to blame for the problem you are describing.
You should really get a tach and temp gauge too. it really helps to tune these scooters.
