Light weight drive face
veedubh20
Re: Light weight drive face
Post by veedubh20 »
Chameleon drive face not very cheap! :surprise:
sanjuro
Post by sanjuro »
Trafficjamz wrote:
sanjuro wrote: Where could I get a Chameleon drive face?
Does the Malossi Variator come with its own ramp plate?
I got mine the last time I was in Tokyo, but WeBike has them online.
Yes, the malossi comes with the ramp plate, variator, drive boss and rollers. Just install as is and it's good to go.
sanjuro
Post by sanjuro »
Here you go:
http://japan.webike.net/products/20259566.html
Not cheap, but well worth it.
Is it actually larger than the PG?
sanjuro
Post by sanjuro »
If it was any larger the teeth wouldn't line up with the gears on the starter motor.
LMH
Post by LMH »
With the Naruku you cant use the starter, it will chew it up. The pitch on the Naruku is greater than the PG and it isnt as tall (not as in diameter) as the stock or PG drive face, maybe 2 mm shorter. If you use it daily it will chew your belt up also as it forces it to ride extremely high in the front and pinches it low on the rear pulley, and that is why I would recommend it only for the track. No experience with the chameleon but they make good products.
The Naruku will give a great top speed but better have a strong rear center spring for off the line.
sanjuro
Post by sanjuro »
The one thing I strive for is balance. Instead of getting the widest diameter outer piece I get one that can still be used with the electric start and make up for it in a taller primary gear.
maddog
Post by maddog »
charmlion only made an exhaust which was great, pg front face is only good for mini strokers
sanjuro
Post by sanjuro »
maddog wrote:charmlion only made an exhaust which was great, pg front face is only good for mini strokers
Once again, you're woefully uninformed.
'Dog, what has happened to you?! You used to post something useful at least once in a while. I can't remember the last time I read something of yours that had any value whatsoever. Sheesh! Here's my PG Al-You-Minnie-Yum face:
The pic is typical Wheel-lousy, but it appears ALL of my Sharpie line has been erased, right out to the edge. This suggests the face really lets me use the whole range of the longer 669 ZX belt I'm usiing, and why Flash exceeded 70 despite that longer belt - which usually limits top speed but gives better take-off. I had gone 69.9 with a 654, but barely exceeded 65 using the 669 until I tried it with the PG face. I take back my previous remark that the PG face has no effect on performance. It gives the best of both worlds IF you shim the boss to the belt accurately.
Downsouthdio
Post by Downsouthdio »
Thanks for your info wheelz
Honda super dio
Corsa
26mm
Sparrow
281.2 grams -vs- 124 grams
Here is a video showing the difference between a stock drive face, and a ZX aluminum drive face.
LMH
Post by LMH »
The kymco zx uses the heavy steel one also, is it the dio zx that comes stock with an aluminum drive face? Your blue one looks like the Naruku drive face and is the same weight as one.
sanjuro
Post by sanjuro »
The Honda Dio zx oem is the heavy steel variety.
