What do you guys think of this new ride?
deuce217
Re: What do you guys think of this new ride?
Post by deuce217 »
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Post by eliteguy50 »
Forward airbox and perimeter r bolt cap. Without a doubt, that is the H. Minarelli.
Your luck may have continued. That Top pipe is quality you might even have a Top Trophy bore kit on there.
deuce217
Post by deuce217 »
eliteguy50 wrote:Your luck may have continued. That Top pipe is quality you might even have a Top Trophy bore kit on there.
Cool, I saw a few videos on youtube of the pipe. That would be awesome if this had a BBK of decent quality. When I looked under the bike in the dark and saw the pink I was thinking this cant be stock, but I know nothing about these other than what the manual states (which I have read through almost 3 times already). I need to clean the carb, and change the gas. Currently it only will go about 30 mph and wont hit high rpms. Also it will not run with out the choke on, I am thinking other than old gas, the jetting may be way off as well. I also feel the rollers shift up way too fast. on the stand it sounds pretty healthy and revs quick. Faster than my AF16 Dio that is dialed in with pipe and BBK.
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
50mm BBK (tai)
V-8 pipe
stucinthe80z
Post by stucinthe80z »
nice very nice
Downsouthdio
Post by Downsouthdio »
Really nice bike..im pretty sure that came factory with a dellorto 21mm too.. And thats a very nice pipe
Honda super dio
Corsa
26mm
Sparrow
deuce217
Post by deuce217 »
Thanks guys, I will look into the carb hopefully tonight. I planned on getting into it last night but I had to fix a friends little 250 ninja. That hard to work on that bike knowing this one needs to be tuned. I have been checking into jetting on some other aprilia forums but have had no luck finding a basemap/ rough tuning guide for the 70cc BBK. Any insite would be nice. Now with this being water cooled it is probably not as easy to tune off temp readings? I would assume since it will probably tend to run cooler. Later, I am terribly late for work!
50mm BBK (tai)
V-8 pipe
Downsouthdio
Just stick with a 19-21mm dellorto or arreche.. Jetting start with 85 main.. Should be between 85-95 on main
Honda super dio
Corsa
26mm
Sparrow
deuce217
Post by deuce217 »
Downsouthdio wrote:Just stick with a 19-21mm dellorto or arreche.. Jetting start with 85 main.. Should be between 85-95 on main
Thanks DownSouthdio, I will report back.
50mm BBK (tai)
V-8 pipe
Downsouthdio
Also keep the airbox not an open filter.. Alot easier to tune with pretty much same performance and less noise
Honda super dio
Corsa
26mm
Sparrow
deuce217
Post by deuce217 »
Thanks so much down south.
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
Image yes it is the TOP kit!
The carb is a 24mm
It is very very dirty, this bike has sat since 2004
50mm BBK (tai)
V-8 pipe
deuce217
Post by deuce217 »
I bet this is why it will only run with the choke on full, is probably not getting enough fuel from the idle/ slow jet because of all the varnish and other nastness inside. The intake tube also has cracks, I need to get one on order.
50mm BBK (tai)
V-8 pipe
Did you get the stock parts?
