Page 2 of 3
Re: biggest carb for a spree?
Posted: Thu Oct 04, 2012 10:12 pm
by bradbutlernc
Ive had it to 40 with a stock engine, bigger rear tire, and ax24 belt swap.
Posted: Fri Oct 05, 2012 12:52 am
by abreen89
bradbutlernc wrote:Ive had it to 40 with a stock engine, bigger rear tire, and ax24 belt swap.
that what the speedo says on your spree not ure actual speed gps verify everything.. and if you get gears their is no way you can get to full speed or even high rpms without going down a mountain.. its like starting a 5 speed in 3rd gear......
Posted: Fri Oct 05, 2012 7:41 am
by bradbutlernc
Im modding the clutch for higher stall as well, the torque multiplication of higher rpms should give it quite a bit more go off the line. Listen to the stall speed of the new scooters, its quite a bit higher than the old school stuff. A friend of mine just got a 2012 yamaha zuma, i told him im gonna spank him with the spree when i get it together, lol.
Posted: Fri Oct 05, 2012 2:00 pm
by paulpauly7
this thread gets funnyer every post
Posted: Fri Oct 05, 2012 4:35 pm
by abreen89
bradbutlernc wrote:Im modding the clutch for higher stall as well, the torque multiplication of higher rpms should give it quite a bit more go off the line. Listen to the stall speed of the new scooters, its quite a bit higher than the old school stuff. A friend of mine just got a 2012 yamaha zuma, i told him im gonna spank him with the spree when i get it together, lol.
well let us know how it goes and post some vids.. not many people have messed with the spree clutch that i know of.
Posted: Fri Oct 05, 2012 6:14 pm
by paulpauly7
any aftermarket grab springs can be used you just have to shorten them by triming some off the end heating it up and bending a new hook on to it
wow you guys are noobs
Posted: Fri Oct 05, 2012 7:48 pm
by bradbutlernc
Ive built briggs 5hp racing engines for 10 years, i know a little about centrifugual clutches. Weigh it, drill/grind a few grams off, see results, remove and do again until desired stall. Same concept as with the governor in my Buick GNX transmission. Easiest way without forking around with the springs.
Only pic i have right now is a crappy cell phone one of the head getting cut on the lathe.
Posted: Sat Oct 06, 2012 12:41 am
by patthesoundguy
I say giv'er! Ya got nothing to lose. This thread is what it should be all about, taking somthing that was never ment to go fast, modding the heck out the original parts and fabbing up some other stuff,. Then drive the living crap out of it untill it breaks or not. Learn from what diddnt work fix it and drive the crap out of it again... that's fun right there :-)
Posted: Sat Oct 06, 2012 7:51 am
by bradbutlernc
I like making stuff fast that wasnt intended to be. One of my cars is an 81 Pontiac Catalina, typical grandpa sedan, actually passed down to me from my grandpa. I yanked the 3.8 v6 out of it in favor of more power. Built a 500 horse/600ft lb of torque stroked/bored 468 Olds engine, built trans, rear, etc etc. Now grandpa turns a quicker 1/4 mile than a z06 corvette, with a trunk full of groceries. Makes a good sleeper, hopefully the spree will do the same. :coolcruise:
Posted: Sat Oct 06, 2012 10:53 pm
by abreen89
paulpauly7 wrote:any aftermarket grab springs can be used you just have to shorten them by triming some off the end heating it up and bending a new hook on to it
might just be over your head...
Posted: Sun Oct 07, 2012 2:44 am
by paulpauly7
thats funny BOY
Posted: Sun Oct 07, 2012 7:51 pm
by bradbutlernc
Heres my new carb, a TK 19mm :naughty: Image
Posted: Sun Oct 07, 2012 9:24 pm
by abreen89
that one hasw the electrric choke it looks like too!! Cool.. Did you have too machine an adapter for it to fit the intake?
Posted: Sun Oct 07, 2012 11:13 pm
by bradbutlernc
Yea, a buddy of mine made me an adaptor to bolt to stock intake, i will be porting the intake to open it up a little bit too. Im just going to join the carb to the manifold with a 1" heater hose. May have some issues with the throttle cable, i guess well see how that goes when the time comes.
Yes that is electric choke, plugs right up to the honda plug too :smile: The carb is a brand new TK 19mm 2 stroke scooter carb, factory on some 50cc 2 strokes. Should wake the spree up nicely. It uses mikuni jets which is nice too. Wonder how bad my gas consumption is going to go down though
Posted: Sun Oct 07, 2012 11:16 pm
by bradbutlernc
I would consider buying the CT intake, where do you get it from though?
