The solution to a carbon-caked exhaust is to de-carbonize. I would avoid unproven modifications that cannot be undone. Drill at your peril.
'86 Spree won't start
Re: '86 Spree won't start
"The solution to a carbon-caked exhaust is to de-carbonize. I would avoid unproven modifications that cannot be undone. Drill at your peril."
It WAS perilous riding along at 5 mph. Here in Indiana you are an easy target for half empty beer cans, tobacco spit or corn cobs at that speed.
I knew the muffler was clogged when I swapped in one from an '87 elite which worked but stuck out the side about a foot. Different engine. So swapping out one part for another is not a bad way to isolate a trouble spot. Gonna have to look into de-carbonizing the proper way. But the muffler may be the problem and if you can't throw the muffler into a bonfire like in California or pay for a chemical fix then maybe the quickest cheapest way is best. A little metal patch from autozone and the muffler is good to go. I will post a pic of the damage. It will be a small photo.
