MORE VENTO PROBLEMS...
Re: MORE VENTO PROBLEMS...
sounds to me like something bound up in the gear- more then likely bearing broke casing striped the tooth- your gonna need new bearings too- they arent too much- it sounds like a big job- but id rather swap out the gears any day of the week- can u post a picture?? will help a lot-- i had several vento's before
i find the bearings they use suck pretty bad- first thing i do is upgrade them on my builds-- if your turning more rpms you need better bearings
Oh I was probably doing 50-55 the night before. Lolol.
But what size bearings?
I've not got an answer for that yet..
2004 Vento Zip R3i Turbocam
is it a 40qmb- printed on engine or cvt case
I appreciate the link, but I don't have the money for it lolol.
the engine should be a 40qmb, but i know the zip gears are different from the triton, but id just swap the whole engine out- piecing together stuff is going to cost you at least 120 anyway
i might be getting a vento zip in a few weeks- if i change my gearing i can sell u the old ones
Alright, I really don't have A lot of money... I'm only 16 Haha. But if you ever do change the gears out, Let me know and I'll do my best to try to get them.
look up some diagrams or schematics for the gearbox on the 40qmb, or vento zip engine- then once your realize how it all goes together - you will be able to tell what needs to be replaced- but if it doesnt have teeth its bad lolOkil69 wrote:Alright, I really don't have A lot of money... I'm only 16 Haha. But if you ever do change the gears out, Let me know and I'll do my best to try to get them.
ended up getting a vento zip too- let you know if/when i swap gears
