I have a Different Effective way of cleaning the Carb.
Farfignugin
Post by Farfignugin »
so where can u get this "seafoam" stuff, and about how much does it go for?
kurremkarm
Post by kurremkarm »
I got mine at an autozone it was like 5 bucks.
jbarb
Post by jbarb »
Ive heard nothing but good things about this stuff. I might have to try it.
MySpree
Post by MySpree »
yea, also if u take it apart u can find that maby the carb was clean, but a part was broken or not there, or maby just not set right.
Farfignugin
yes but by taking it apart u could have caused that part to break or fall onto a floor and never find it again.................
MySpree
Post by MySpree »
well if u break a carb apart trying to vlean it then they should have opayed someone to do it.
Farfignugin
what if it was one of those "accidents" even those mechanics can do that....
mopedman
Post by mopedman »
you all are soooo dumb why dose everyone argue about every thing in every post, the guy that put up this post was trying to be helpfull, i am going to try it and see if it works good and if it dose i am going to put it in tec docs
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Plooster
Post by Plooster »
mopedman wrote:you all are soooo dumb why dose everyone argue about every thing in every post, the guy that put up this post was trying to be helpfull, i am going to try it and see if it works good and if it dose i am going to put it in tec docs
Sorry, noiseguy already put in in there almostly immediately after this thread started.
I have a 1986 red Honda Spree
mods: uni prefilter, two 3/8 inch holes drilled in airbox lid, drilled jet out from .026 to .0292.
I also have a 1999 Yamaha Blaster
stock except Graydon Proline Nerfs Holeshot tires and aluminum rims.
mopedman
Post by mopedman »
oh ok i didn't see that
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
MySpree
Post by MySpree »
dude sam u are jsut trying to oceruse ur powe!!!!
Spreewell
Post by Spreewell »
I did it a couple more times and now my Spree is going 50MPH! This is the best.
MySpree
Post by MySpree »
ok ur a liar and my eltie goers 50! cuz its MODIFYED!
Plooster
Post by Plooster »
Hey Myspree, I sent you a PM.
Thanks
mikeb
Post by mikeb »
ummm, i'm guessing the reason you are running faster is because you are decarbonizing your head when you run that stuff. same effect as misting water into a carb, except it's safer.
sure it probably cleans the carb too, but seriously, how lazy can you be not to just take the carb off and spend seven minutes cleaning the thing. then you can use compressed air and be sure that everything is clean and then inspect it too.
btw - i don't like the stuff. i call it headgasket eater cause it cleans out so many deposits in cars that it leaves holes where deposits used to be. on a moped it probably doesn't matter as much though - so go nuts.
1980 motobecane sebring : 1989 razz : 1985 spree : 1987 spree : 1986 spree : 2002 yamaha vino :1971 cb100 : 1998 civic : 2002 s2000
