Piston to cylinder clearance
tazland001
Re: Piston to cylinder clearance
Post by tazland001 »
Stole the words right out of my mouth Baka. He is right like usual. And also your to lean on the main.
At least you only soft seized it once and you still have good compression.
Taz
Duke
Post by Duke »
I was running 100:1 premix plus the oil pump , still not sure exactly what went wrong. Maybe I was running it too hard too early, I am a bit impatient when it comes to break-in!
87 Elite 50
99 Aprilia SR50 Carb polini
1973 Suzuki TS185 smoker!
2002 KTM Duke
Duke
Post by Duke »
It really sounds awful now and has lost power, it vibrates badly off throttle and sounds nothing like it did before the seize.
87 Elite 50
2002 KTM Duke
Duke
Post by Duke »
Last compression check at 110 psi, its officially toast!
I just pulled the jug and the piston has been slapping madly in there, not salvageable at all. Last SB50 I built with the complete stock size cylinder and piston kit from Taz. It is still running fine but the porting on it sucked and it looked like the chamfering had been done by a drunk with a dremel! I still have a spare cylinder which could be bored .5 over if I could find a nice OS piston... I am really keen to stick with Honda parts as I have yet to see aftermarket cylinders of any quality. Back to the drawing board... :eyeroll:
87 Elite 50
2002 KTM Duke
paulpauly7
Post by paulpauly7 »
hit up taz for the complete 44mm kit or pm NZHONDA he has a complete unused 48mm kit just sitting there he cant use
deuce217
Post by deuce217 »
Dont give up! BBK's are reliable, do you use a temp? 30.00$ goes a long way towards success. There are enough guys on this forum, we can figure your build out with you. Half the fun is the reward of accomplishment.
-Evan
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
Duke
Post by Duke »
Well I am still breaking in and tuning my Malossi / Aero 50 combo but this one is for sale sooo....
Variator trumps a silly old 44mm bore anyday :bowrofl:
I had an SE50 donor just sitting there staring at me so I did a one day motor swap!
40 mph plus :ndance:
87 Elite 50
2002 KTM Duke
paulpauly7
As i and others have said its easyer to fit a se50 variated afo5e or af16 to a spree or elite than it is to fit a big bore kit and tune it .And the variated motor will smoke any spree or elite unvariated motor
tazland001
running compression for stock to 44mm is 90-120.
Also suggesting that it is easier to swap and engine than to install a BBK and tune is just hilarious.
Did you think going 3 full sizes up was going to make the scooter hit 45mph and do wheelies?
And yes a variated engine will out perform a solid pulley engine. We already know this paul. You sound like a broken record.
The engine swap looks good and sorry to hear you had problems with both your BBK's.
paulpauly7
well people havent got it thru theres heads and keep wasting money on the spree motor hoping it will go fast
Duke
Post by Duke »
No worries , Taz it was doomed from the start because the tolerance was wrong. My Malossi is doing fine, just needs some fine tuning.
The 44mm piston I got from you actually still looks usable, the rings weren't trashed it was just slapping against the bore. I will live and learn on this one. My brother did a great job on the head with a 5-axis CNC!
87 Elite 50
2002 KTM Duke
z50r-ghost
Post by z50r-ghost »
... That head DOES look good ...
Nice work!
-j
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
