stuck screws.
Dust-it
Re: stuck screws.
Post by Dust-it »
Add
Mouse Milk
AreoKroil
Great for braking lose stuff if you have the patience .
otto-man
Re: stuck screws.
Post by otto-man »
Dust-it wrote:Japanese have their own standard for Phillips head screws .They have a little different angle in the slot .
If you start with a hand held impact driver and the correct Japanese standard bit they will come out (well most times ).
Ever notice what your screwdriver does to very tight carb bowl screws?
I know that doesn't help on the ones you already mangled . If I cut a slot with the dremel I still use the hand held impact
driver . Found out about impact drivers in the 60's trying to remove screws from Japanese dirt bikes , but didn't know about
the difference in Phillips heads till much much later !
Good Luck
Where can you get a set of Japanese Phillips bits!!!!
Re: stuck screws.
Bolt and fastener stores in the Bad Part of Town should be aware of weirt Japanese-Spec Phirips head sclews. That or Tokyo.
I had the issue with my 1971 CT 70. Even Harley riders know not to try to drop the bowls on their Keihin carbs using Wal-Mart Stanley tools. Instant mushed screw head and much cussing ensues. Never had much luck with cheap Chinese hand impact drivers either. On a 1980, torch or notching the head and taptaptap counterclockwise with a lot of patience.
mmeadows
Re: stuck screws.
Post by mmeadows »
so finally i got them all out! sometimes with pliers, sometimes with impact, sometimes with drills....
i went to lowes and bought all new 10mm bolts for about $5.00
on the other side of this case/clutch/chain cover is .75qt of 10w30 oil. the owners manual shows it being filled up with the bike laying on the ground! oem sacrilege.
4 qts later i learned it is impossible to balance and line up the case cover and a home made gasket with the other half of the case without spilling oil everywhere ( once you spill it you have to start over, as there is no fill tube/ bolt hole)
im probably going to sell this bike so i don't want to spend 15 on a gasket. would liquid gasket work here? like the kind you use to put engine cases back together
