Page 2 of 2
Posted: Sun Jul 30, 2006 8:34 pm
by mikeb
joejoe wrote: i had no air filter so i used a gasoline fumed rag 8) LOL!
wow.
recipe for xplosion
Posted: Sun Jul 30, 2006 9:35 pm
by Gamemedic
Get a meter and test the bystarter. You should have no more than 10ohms between the 2 pins on the connector. Did you set the air screw at 1 3/8 turns out?
Posted: Sun Jul 30, 2006 11:38 pm
by joejoe
OK guys i said GAS FUMED not soked lol i used the rag to wipe my hands off after the carb clean i knew that would have a few comments lol 8)
the air screw was in a few different locations but it was always close to the 1 and 3/8 turns
Posted: Mon Jul 31, 2006 8:58 am
by Farfignugin
still, that is dangerous. you should AT LEAST get a sponge that will fit in the airbox (or cut down a larger one) and soak it in gear oil. But getting a real air filter would be best.
Posted: Mon Jul 31, 2006 11:02 am
by Gamemedic
Sounds like you might be getting to much oil, not enough gas. You said the headlight dimmed...your mag might be going, that would also give you a weak spark. Get it started again and measure how much voltage you have going to the batt. You should have around 12.9-13.4 at idle. Check all your grounds...A lose or dirty ground connection will mess with ya' too. Change your plug again(when working on 2 strokes always keep lots of plugs around)
