oil plug leaking
bonesv
Re: oil plug leaking
Post by bonesv »
The plug I have has a threaded hole in which I fitted a couple of washers on to with a bolt.
The large washer was big enough to drill a hole into which allowed the use of the original pumps'
retaining bolt. As you can also see, I used the o-ring from the oil pump, as well as the included o-ring, so no Hondabond or hammering was necessary. The plug slides in easily and firmly, and sits flush to the block and can not move in any direction.
I have not had a leak once on either of my motors.
I hope this helps anyone who has not had experience with an oil pump plug. Of course there are many other ways of accomplishing the same results successfully.
paulpauly7
Post by paulpauly7 »
nice job i use a 100yen polished coin to hold my plug in lol
Cherreh SR
Post by Cherreh SR »
bonesv wrote:The plug I have has a threaded hole in which I fitted a couple of washers on to with a bolt.
Excellent guys! Thank you very much the pictures you provided are the perfect explanation on how to do this.
