Oil Plug blown Out!!!!!!
Re: Oil Plug blown Out!!!!!!
paulpauly7 wrote:would someone be silly enough to fit a kit with no base gasket ?
... Do you really need to ask?
195 sounds high. Is your exhaust plugged up?
WeeMan
Post by WeeMan »
Its a brand new SP3 with the washer removed so I hope not lol.
milkhuman wrote:pretend its a roofing nail. or, i mean. drywallo, the small, thin ones. thats about, how hard. as soon as y8ou hit it with something hard, itll slam right in. it's just rubber needing to squeeze in.
I measured the plug and it is 2mm longer that the oil pump is. I dont know if this makes a difference or not? I tried to hammer it last night but just got a tinking noise. It just slides in up to 2mm short and then wont go.
Cheers
Danny
paulpauly7
Post by paulpauly7 »
trim the end of the plug
WeeMan
Post by WeeMan »
paulpauly7 wrote:trim the end of the plug
That was my next step. I presume they are solid aluminium? I justt was not sure it was at the end where it was getting stuck but I suppose its not gonna hurt if I take it off the end and it still does not fit.
paulpauly7
how many time have you been banned now im loseing count
WeeMan
Post by WeeMan »
Ive sorted it now.
I'd need a picture of this plug. Seems like it should be retained by the factory oil pump bolt.
Red Eft Performance
Post by Red Eft Performance »
sometimes the plug wont sit flush with block so you need to add a washer or two on top of the plug.
This is trafficjamz picture. looks like this plug is flush with the block.
Red Eft Performance
View products click => Here
WeeMan
Post by WeeMan »
Red Eft Performance wrote:sometimes the plug wont sit flush with block so you need to add a washer or two on top of the plug.
Mines definately not flush. I did take a couple of mm off the end but it did not make a difference. It must be some where in the middle. However as long as it seals with the o ring and I make sure I bolt it like the picture above it should be fine I think.
Cheers
Danny
kingkamehameha
Post by kingkamehameha »
Use some hondabond just in case
That picture is what I'd envisioned as the retaining scheme. Hard for that to blow out...
WeeMan
Post by WeeMan »
noiseguy wrote:That picture is what I'd envisioned as the retaining scheme. Hard for that to blow out...
Hi Noiseguy,
I had it plugged in without the retainer so it was basically just staying in on the o ring. I looked on the wikispreedia and saw a picture with someone just pushing it in and it did not show a retainer but it makes sense to have one. I have now fitted it with a new o ring and although it does not fit flush its only a mm out so I have just put a 1mm washer under the retainer so its level. I have also Honda bonded it as advised so it should be ok now.
Cheers
Danny
paulpauly7
you will be fine good job. Last thing you want is a air leak
JJ Joseph
Post by JJ Joseph »
If the plug isn't seating right, are you sure the plug isn't bumping into the oil pump drive gear below? And why not just leave the oil pump in place? It's useful and it fills the hole nicely.
