Or you need a blow through carb.
That carb isnt designed to see positive pressure.
Cool build!!!
jareeb wrote:boost test video. showing that it does in fact compress air. http://youtu.be/wf957RfQv2k
jareeb wrote:you are correct bud. it was the only way i could think of bending it. i used a hand saw, pliers, and c clap. then welded in the channel. screws held it onto the wood so i could drill it.
