Re: 84 spree bbk - goin' GROOVY
Posted: Fri Aug 30, 2013 10:27 am
I think my kit came without those instructions, or I misplaced them (definite possibility!) I was loathe to drill my air box top, and have opted to dremel a 2 little soda bottle into a hackable intake mod. My carb tube is attached to what I've jokingly referred to as a "velocity stack".
I figure I could add holes while monitoring head temp over a couple breakin rides. For that my fool self got a VDO CHT (vapor would have been easier all around) and spent last night cutting apart a marvel mystery oil bottle... This thread needs pictures!
Pat, as far as my soft seizes went I thankfully only lost about 10 psi. I will be monitoring head temps and swapped in the 8 plug too. You are dead on about richness! Regarding the head the groove modification is said to improve burn characteristics, including running cooler when lean (I am wrapping my head around that one, unsure how that would occur). It is said to produce more low rpm power (also even if lean).
If nothing else it might scrap my dremeled head requiring me to get another and have it professionally milled! When I get to this stage I will do a solder squish test to verify clearance over my piston - if there is room, I might shave it down beforehand. First things first, tuning my stock intake/exhaust (possibly with a 2 little) before swapping gears. Then I'll port match the larger reed block to my intake pipe (reduced top end for low end acceleration, eh?) if all goes well grooves will follow the full setup! Then saving pennies for an mlm pipe if they don't sell out... If grooves work I won't need an adjustable pilot!
Are you opposed to groove testing/application?
