Page 2 of 2
Re: 1984 Spree no start
Posted: Sun Sep 29, 2013 1:00 am
by patthesoundguy
Dont call it a pos it might get upset
its not the motor's fault its worn out or was poorly maintained before you got it
Posted: Sun Sep 29, 2013 8:19 am
by stevemilz
Thanks Pat
Posted: Mon Sep 30, 2013 10:57 pm
by stevemilz
Installed new piston and rings...still not working. I will be doing another compression test to see where its at....
Im going to borrow a Aero 50 carb that I know works just to make sure....
Anyone have any cheap running motors?
Posted: Tue Oct 01, 2013 12:55 am
by patthesoundguy
stevemilz wrote:Installed new piston and rings...still not working. I will be doing another compression test to see where its at....
Did you hone the cylinder before installing the new piston and rings? You may have other issues. Maybe the crank seals are gone. Did you prime the motor with some two stroke mix. Is the battery charged up?
Posted: Tue Oct 01, 2013 6:47 am
by stevemilz
The cylinder was new also(coated with GN2), and yes I did use mixed fuel because I don't really trust the oil pump.
Thanks again Pat
patthesoundguy wrote:stevemilz wrote:Installed new piston and rings...still not working. I will be doing another compression test to see where its at....
Posted: Tue Oct 01, 2013 8:29 am
by patthesoundguy
Wait a min... Was the new cylinder this one?
http://www.ebay.com/itm/HONDA-NQ50-SPRE ... 93&vxp=mtr
If it is, did you cut the base gasket to match the block? The base gasket in those kits are wrong and need some cutting to make them right. It won't help low compression but fixing that issue will get you closer to running. I'm wondering if the cylinder ports are really blocked from the wrong gasket could it not get enough air in to make compression in the first place. Its a theory only but If a motor is an air pump, its not going to pump very much pressure out if it cant take in enough air in.
Posted: Tue Oct 01, 2013 8:36 am
by patthesoundguy
Stock gasket in green
Gasket with that cheap eBay cylinder kit
Posted: Tue Oct 01, 2013 8:41 am
by patthesoundguy
stevemilz wrote:The cylinder was new also(coated with GN2), and yes I did use mixed fuel because I don't really trust the oil pump.
Thanks again Pat
you can trust the oil pumps they usually pump too much oil when then fail. But running premix was the right thing to do though especially when breaking in a new cylinder and with the unknowns with the motor. Once it runs you will be able to confirm the oil pump works
Posted: Tue Oct 01, 2013 8:56 am
by stevemilz
Thank you sir, I know what I'm doing after work...........
