Page 2 of 4
Re: Dio motor prospect :-)
Posted: Thu Sep 26, 2013 7:55 am
by patthesoundguy
veedubh20 wrote:use the honda oem cooling white fan only...
Dont use the aftermarket fan!!... fail!!!
Thanks for the heads up
I love all the input you guys have B-)
Posted: Thu Sep 26, 2013 2:13 pm
by paulpauly7
thats how i like them
Posted: Thu Sep 26, 2013 8:16 pm
by patthesoundguy
graphite9 wrote:Dio+corsa+pg long, polini 3 shoe clutch and variator with a set of 9:1's and your spree will be seriously unsafe...perfect.
Unsafe usually equals fun B-) my spree with bbk carb and pipe is the tons of fun, when get my hands on that second spree that will be the dio spree
I'm stoked for sure, its gonna be epic as the kids say now
how fast will that go with that setup?
Posted: Thu Sep 26, 2013 9:24 pm
by patthesoundguy
Its official, I called them and gave them my ccard number, and it went through. They will be shipping it tomorrow I think
Posted: Thu Sep 26, 2013 11:39 pm
by kingearwig
with 9:1 and a 3.50x10 tire on my dio with a mini stroked ruima with mild exhaust port work and a v8 i hit 60mph. course mine isn't a swap so you might do better. And with those trans parts a wheelie will be a flick of the wrist at nearly any speed.
Posted: Thu Sep 26, 2013 11:48 pm
by patthesoundguy
If i came any where close to that id be over the moon.
Posted: Fri Sep 27, 2013 1:58 am
by paulpauly7
im glad ive inspired someone to be crazy
Posted: Fri Sep 27, 2013 2:05 pm
by patthesoundguy
paulpauly7 wrote:im glad ive inspired someone to be crazy
And you have done it very well
im nuts anyway B-) every one thinks im crazy just for driving somthing so small as a spree in the first place
sprees are uber rare here in my neck of the woods. Ive only seen two others since ive gotten mine. One was for sale on the online classifeds locally years ago and the other im getting for me from a friend
Posted: Tue Oct 08, 2013 10:02 pm
by patthesoundguy
Update B-)
The motor showed up on the doorstep today, but I had to head out to a gig, so I couldnt look too hard at it yet. The exhaust port is huge so im sure it has a kit on it. And it has a 28mm OKO on it. Ill get the details and my parts list for the wanted for sale section to out fit the motor with the needed missing parts. What would I need to make it run off the frame. Could I hook up a coil and cdi to it and make a stand for it and fire it up?
Posted: Tue Oct 08, 2013 11:31 pm
by deuce217
You will never want a spree motor again other than for comparison to your new power plant. Glad you got one the DIO hype is real.
Posted: Wed Oct 09, 2013 10:33 am
by patthesoundguy
graphite9 wrote:You would need a coil and regulator and cdi. Actually you probably don't need the regulator rectifier. I'd suggest doing it in the bike. Not having a wheel/brake on the rear might cause the bike to rev sky high. I think you need some resistance on the crank. But i may be wrong.
I agree about not having a wheel and brake on the motor might be an issue, that had crossed my mind. I'm glad I asked about it. Thanks for the input
Posted: Wed Oct 09, 2013 1:44 pm
by patthesoundguy
Ok guys is this model a dio model number
and the cylinder looks to not have been run yet
its a 51mm bore
Posted: Wed Oct 09, 2013 1:52 pm
by patthesoundguy
I think this motor is getting another top end
the boost ports arent chamfered and the exhaust port is kinda off.
the ports can be chamfered of course, I can do that in my sleeep but i think id like to build this right if Im gonna do it at all
Posted: Wed Oct 09, 2013 2:20 pm
by paulpauly7
nice to see a af18 here for a change.Now is it a large crank shaft or small ? variator bolt will be either 14mm (small) or 17mm (large) red eft has malossi cranks for both the small crank shaft is pretty cheap
Posted: Wed Oct 09, 2013 2:23 pm
by patthesoundguy
paulpauly7 wrote:nice to see a af18 here for a change.Now is it a large crank shaft or small ? variator bolt will be either 14mm (small) or 17mm (large) red eft has malossi cranks for both the small crank shaft is pretty cheap
Crap just had the cover off :O ill pull it again and look
