help. my 86 spree motor starts and runs backwards.
ped
Re: help. my 86 spree motor starts and runs backwards.
Post by ped »
yamahauler660r wrote:the magnets in the flywheel polarity may have gotten reversed. My father in law had to weld a part of a flywheel on a arctic cat sled and it went in reverse when he got it back together. it even started with the pull start and sounded completely normal
try a different flywheel
thanks for the info.
yamahauler660r
Post by yamahauler660r »
:thumbwink: let us know what happens
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
86/96 "Spree S/SpreElite"
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
patthesoundguy
Post by patthesoundguy »
My Yamaha G1 two stoke golf cart motor runs in reverse and forward, that's how they back up ;-) you have to post the video, it will be the coolest video if you can drive backwards at all B-)
SkorchIndustries
Post by SkorchIndustries »
Where's the video?! :thumbsup:
ped
Post by ped »
SkorchIndustries wrote:Where's the video?! :thumbsup:
No, no video :( . i'm doing a AF16 motor swap :D . you can see some of the photos under (first spree AF16 motor swap) :thumbwink: .
a video would have been funny :lol: , but how would you drive backward :werd: ? I tried. its very hard to look back and balance yourself at the same time. :crazy:
it's like taking your spree on a hill and rolling backwards. how far would you get? :crazy: don't do it too risky. :crazy: your just asking for pain. :lol: and some missing teeth :lol: .
ped
Post by ped »
spreeinkc was right. think the timing is off. no matter now I did the AF16 motor swap. :smile:
ped
Post by ped »
ped wrote:spreeinkc was right. think the timing is off. no matter now I did the AF16 motor swap. :smile:
I painted the frame, body twice, wheels, change the shock mount, rear tail light, the wire connections, longer brake cable, kickstand, grease the forks and wheels, you should know the fork bearings are lose. and motor work. :2thumbs:
spreeinkc
Post by spreeinkc »
It's possible to ride backwards but not very easy. This isn't quite the same thing but he is riding backwards... lol
http://youtu.be/U2T3yWtTBGM
Tried to get video to show up here but guess I don't know how...
<iframe width="560" height="315" src="//www.youtube.com/embed/U2T3yWtTBGM" frameborder="0" allowfullscreen></iframe>
<object width="560" height="315"><param name="movie" value="//www.youtube.com/v/U2T3yWtTBGM?version=3 ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/U2T3yWtTBGM?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
This was at the annual ROC (ride of the century) held in St. Louis. Largest sportbike meet in the Midwest by far. Several thousand bikes each year. HiPo have tried to stop them a few times but don't even come close.
ped
Post by ped »
hello spree owners . yes I posted the spree runs backwards help post. unfortunately I pull the motor off and did the AF16 motor swap. :smile: before it took any video of the motor running backwards. :sad: its impossible to drive it. I came to find out that the timing is off. and It will only start and run backwards with a drill.
what I will have to do is swap the motor back and take the video. I hate to do all that work again and then swap it back to the dio motor. just to make the video. I still have the motor when I get a chance and have time I will swap it and post the video for everyone to enjoy. :thumbwink:
ped
Post by ped »
hi spreeinkc, I have see that before. what if the motorcycle was facing the other way and you had to steer from the rear? :lol:
that would be epic. :worship:
