Page 2 of 2
Re: help. my 86 spree motor starts and runs backwards.
Posted: Sat Oct 12, 2013 5:34 pm
by ped
yamahauler660r wrote:the magnets in the flywheel polarity may have gotten reversed. My father in law had to weld a part of a flywheel on a arctic cat sled and it went in reverse when he got it back together. it even started with the pull start and sounded completely normal
try a different flywheel
thanks for the info.
Posted: Sat Oct 12, 2013 5:56 pm
by yamahauler660r
let us know what happens
Posted: Sun Oct 13, 2013 12:26 pm
by patthesoundguy
My Yamaha G1 two stoke golf cart motor runs in reverse and forward, that's how they back up
you have to post the video, it will be the coolest video if you can drive backwards at all B-)
Posted: Mon Oct 14, 2013 2:43 pm
by SkorchIndustries
Where's the video?!
Posted: Tue Oct 15, 2013 1:14 am
by ped
SkorchIndustries wrote:Where's the video?!
No, no video
. i'm doing a AF16 motor swap
. you can see some of the photos under (first spree AF16 motor swap)
a video would have been funny
, but how would you drive backward
? I tried. its very hard to look back and balance yourself at the same time.
it's like taking your spree on a hill and rolling backwards. how far would you get?
don't do it too risky.
your just asking for pain.
and some missing teeth
Posted: Wed Oct 30, 2013 3:58 am
by ped
spreeinkc was right. think the timing is off. no matter now I did the AF16 motor swap.
Posted: Wed Oct 30, 2013 4:09 am
by ped
ped wrote:spreeinkc was right. think the timing is off. no matter now I did the AF16 motor swap.
I painted the frame, body twice, wheels, change the shock mount, rear tail light, the wire connections, longer brake cable, kickstand, grease the forks and wheels, you should know the fork bearings are lose. and motor work.
Posted: Wed Oct 30, 2013 11:37 am
by spreeinkc
It's possible to ride backwards but not very easy. This isn't quite the same thing but he is riding backwards... lol
http://youtu.be/U2T3yWtTBGM
Tried to get video to show up here but guess I don't know how...
<iframe width="560" height="315" src="//
www.youtube.com/embed/U2T3yWtTBGM" frameborder="0" allowfullscreen></iframe>
<object width="560" height="315"><param name="movie" value="//
www.youtube.com/v/U2T3yWtTBGM?version=3 ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//
www.youtube.com/v/U2T3yWtTBGM?version=3&hl=en_US" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
This was at the annual ROC (ride of the century) held in St. Louis. Largest sportbike meet in the Midwest by far. Several thousand bikes each year. HiPo have tried to stop them a few times but don't even come close.
Posted: Fri Nov 01, 2013 4:30 am
by ped
hello spree owners . yes I posted the spree runs backwards help post. unfortunately I pull the motor off and did the AF16 motor swap.
before it took any video of the motor running backwards.
its impossible to drive it. I came to find out that the timing is off. and It will only start and run backwards with a drill.
what I will have to do is swap the motor back and take the video. I hate to do all that work again and then swap it back to the dio motor. just to make the video. I still have the motor when I get a chance and have time I will swap it and post the video for everyone to enjoy.
Posted: Fri Nov 01, 2013 4:38 am
by ped
hi spreeinkc, I have see that before. what if the motorcycle was facing the other way and you had to steer from the rear?
that would be epic.
