Parts total $$$$$$1327.43$$$$$$
Million Dollar Scooter Build
Re: Million Dollar Scooter Build
2x polini corsa bores ordered. 500.00
yikes I guess i was lucky i got a 98 SR for $12.50
Who even came up with that number 12.50 hahahaha.
Bought two sets of wheel inserts 75.00
it was two scooters for $25 one was crap so i stripped it to the frame to make a "drag" scooter the other only had around 500 miles and is pretty clean. maybe i missed it but why are you buying two of everything?
GO FAST PARTS
Thanks Taz
Glow in the dark throttle cables, 24mm carbs, 9:1 gears, CT intaaaaakkkeesss
This is looking smooth.
Thanks Taz
First person ever to use 3 variators on 1 scooter
DDX
SEF Ramp plate
DDX
SEF Ramp plate
This looks like it will take me to 60mph.
Tuning Question
I got an elite I fired up. When I turn the air screw out 1 turn from all the way in it revs up. Shouldn't the air screw be turned out 2.5 times. Does this mean I have too big of a pilot jet. I think I put a 48 pilot in a 26mm oko
Too small of a pilot.
Any know where the wiring diagram is for the jdm taillight. I got it all ready to go back together but need the wiring for the tail light thanks.
Roger that LoveMyHonda. think I can get away with a 42 pilot 125 main on a 24mm carb
Also does anyone have any pics to dremel out the carb bowl so I can swap the pilot too. thanks
Hi limp. remove very little at a time until the pilot come out. try not to touch the drain bolt seat. it may leak. take your time. If you drink too much coffee, try at your own risk.Limp1144 wrote:Also does anyone have any pics to dremel out the carb bowl so I can swap the pilot too. thanks
- 20131228_183531[1].jpg (157.73 KiB) Viewed 13202 times
- 20131228_183155[1].jpg (150.61 KiB) Viewed 13202 times
- 20131228_183941[1].jpg (147.36 KiB) Viewed 13202 times
Hi limp. I don't have one but follow the colors on the wires. use your other scooter as a guide.Limp1144 wrote:Any know where the wiring diagram is for the jdm taillight. I got it all ready to go back together but need the wiring for the tail light thanks.
Look what came in the mail today.
Two Polini Corsa bores.
Wheeeeel Insertssss
I might sell these wheel inserts if anyone wants them two sets for 80 plus shipping.
Wheeeeel Insertssss
- KingJeff801
here you goLimp1144 wrote:Any know where the wiring diagram is for the jdm taillight.
http://www.hondaspree.net/phpBB3/viewto ... ght#p80497
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
