So I got the new battery in and it cranks very healthy now. When it does get "stuck" as I call it, I drain the gas in the carb with that screw and it usually cranks again no problem. By stuck, I mean I'm pressing the start button and nothing happens. I hear the relay click, but no cranking. Then it cranks again fine.
Still wont start. Its getting gas, its getting oil, the plug is new. I even tried the old plug and nothing. So, I think its not getting spark. I put my voltmeter thing on the ignition coil and cranked and it read 0.00 with an occasional 0.03 for a second. I don't know. Maybe the coil went bad?? The gap is correct I think.. its a dime sized space between the electrode and the metal. Grrr this thing.
Oh, and I took the spark plug out completely and cranked it over to get some of the excess oil out. The new plug was COVERED with oil before I did that.
When I tested it with the electricity-o-meter I put the leads on these silver tabs and cranked. Figured I should see something other than 0.00??! Yes green is neg. I know. Can the coil go bad just by sitting out?
