Thanks.. Yes Clear coat planned before Final Assembly.. No old shroud was broken, waiting on another one to get here..Wheelman-111 wrote:Greetings:
Best-looking scooter I've seen in a while! Are you clear-coating over the decals, for the Cherry on the Parfait?
But is that a bare-nekkid cooling fan I see? I sure hope your're not running Shroudless!!
My 87 Elite 50 125cc stroker Build..
Hppowdercoatings
Re: My 87 Elite 50 125cc stroker Build..
2001 Elite 72cc...http://www.hondaspree.net/phpBB3/viewto ... =4&t=31369
1984 Spree "Little Evil" 125cc AF16.. http://www.hondaspree.net/phpBB3/viewto ... 16&t=31569
Hi HP.
looks very nice
looks very nice
Hppowdercoatings
Got the New Trail Tech Vapor Stealth Today..
Mounted it in the stock Gauge Location.. I think it turned out pretty good.. Now I just have to wire it up..
- image.jpg (230.97 KiB) Viewed 5496 times
Hppowdercoatings
Changed up the Exhaust to a side bleed Style. A lot Quieter & no power loss.
Changed the 30mm OKO carb to 28mm OKO , could not get it to run & idle correctly.. Currently Setup 155/50 jetting. Still plan to swap to either a 28mm or 30mm Polini Carb. , they seem to be easier to tune and run Cooler. Running good enough I've started doing some Trans Tuning.
Right now running Polini white Center spring/Green clutch springs & 6x7g rollers , & 9:1 Gears..
This thing is Scary fast , any more then 1/4 throttle and it Turns into a one wheeled Uni- cycle...
Time to swap to some 7:5:1 Gears..
Hppowdercoatings
Fixed the front Disc issues. Powder coated wheels Custom gold metallic...Installed a new Polini 28mm carb from G9 , And set of 7.58:1 Gears from Wheelman-111... Now time to get some Seat/Tune Time..
1man8scoots
I like the color!
How's your tuning? What temps are you seeing?
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
