Page 2 of 2
Re: My 87 Elite 50 125cc stroker Build..
Posted: Mon May 12, 2014 4:49 pm
by Hppowdercoatings
Wheelman-111 wrote:Greetings:
Best-looking scooter I've seen in a while! Are you clear-coating over the decals, for the Cherry on the Parfait?
But is that a bare-nekkid cooling fan I see? I sure hope your're not running Shroudless!!
Thanks.. Yes Clear coat planned before Final Assembly.. No old shroud was broken, waiting on another one to get here..
Posted: Thu May 15, 2014 3:14 pm
by ped
Hi HP.
looks very nice
Posted: Sat May 17, 2014 4:51 pm
by Hppowdercoatings
Got the New Trail Tech Vapor Stealth Today..
Mounted it in the stock Gauge Location.. I think it turned out pretty good.. Now I just have to wire it up..
Posted: Fri May 01, 2015 9:07 am
by Hppowdercoatings
Changed up the Exhaust to a side bleed Style. A lot Quieter & no power loss.
Changed the 30mm OKO carb to 28mm OKO , could not get it to run & idle correctly.. Currently Setup 155/50 jetting. Still plan to swap to either a 28mm or 30mm Polini Carb. , they seem to be easier to tune and run Cooler. Running good enough I've started doing some Trans Tuning.
Right now running Polini white Center spring/Green clutch springs & 6x7g rollers , & 9:1 Gears..
This thing is Scary fast , any more then 1/4 throttle and it Turns into a one wheeled Uni- cycle...
Time to swap to some 7:5:1 Gears..
Posted: Thu May 14, 2015 5:12 pm
by Hppowdercoatings
Fixed the front Disc issues. Powder coated wheels Custom gold metallic...Installed a new Polini 28mm carb from G9 , And set of 7.58:1 Gears from Wheelman-111... Now time to get some Seat/Tune Time..
Posted: Thu May 14, 2015 6:56 pm
by 1man8scoots
I like the color!
Posted: Fri Jul 10, 2015 9:47 am
by whitey
How's your tuning? What temps are you seeing?
