polini manifold and carb test.
Re: polini manifold and carb test.
How much are these manifolds?
- patthesoundguy
When you say adapter do you mean spree block adapter to fit the manifold on to the spree block?
just picked up and running this carb on my elite/dio (corsa, naruku manifold polini 23mm carb and polini filter with stock pipe) still playing around with jetting but think I've found a good spot at 128 MJ with 40PJ thing really rips and keeps the temps low around 260, looks great and remote choke is nice mounted mine up on my rear rack. I was switching over from stock carb so no experience with OKO only problem I had was not a lot of tuning info on here yet but graphite9 is always helpful and glad to see he is testing one.
- paulpauly7
id down jet a little 260 f is rich you want around 320 f to 370 f
bump
any updates g9?
any updates g9?
Pocket Change . Scooter Club
Honda Spree . AF16E
Polini Corsa - Naraku Intake - Dellorto 21mm PHBG - Malossi E8 AirFilter - Malossi Variator 7g - ZX Trans - 9:1 - PG Short
Honda Spree . AF16E
- Rip_City_Spree
I honestly don't think there is much MPG difference from my stock to my 24mm polini. Granted I still haven't really run the * out of it yet. I know it had to have dropped some but haven't noticed a huge drop. I love the carb though G9 did show me A better polini carb the other day and it's nice!
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
So throttle response,fuel consumption, and transitioning are alot better with those polini carbs.. In the end how was the top end effected going to a lower MM carb? The end combo you where using was a dio/ct manifold? and the Polini carb?
One of the best manifolds that I liked using was the Koso Small manifold that I had a few years ago. Plus it leaned straight back then at an angle so I could even run Full spree pannels before I put on my eve pannels.
if you still got this manifold ill buy it from you
Very tempted to try one of these on my vertical Jog. I would think a 19 is in order for my set up. I can use my existing intake and throttle cable that accomodates my OKO? OKO jets too right?
92 Yamaha Jog CY50
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
16 Kawasaki Versys 650
98 Yamaha Zuma
00 Honda Elite 50SR
82 Honda MB5
90 Honda NS50F
14 Yamaha FZ-09
Just had a few questions on this manifold. Can I use a 24mm pwk style carb on this? What's the diameter of the inlet? And is the reed cage simallar to a ct cage?
Graphite, as soon as my CNC mill project is done I am buying some polini carbs from you.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
- Xxbeejay45xx
Saving money for a polini carb setup!! Gotta trust the reviews!!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Just curious. Have you ever compaired oko and polini pwk verison of the same size?
hey graphite9 or anyone running polini 23 carb
Im just starting to work on tuning again on my elite
was running 128 Main and 40 pilot top notch on needle, ran strong but rich could only hit 260 degrees at wot
switched to 110 main (smallest i had) 40 pilot middle notch on needle, has a little hesitation at about 1/4 throttle but runs strong after that still barely touching 300 degrees wot
wondering what everyone else is running so i can get a baseline and also what you are doing for setting on the fuel screw and needle clip
- Rip_City_Spree
im runninng a 24 and currently running a 104 main and 35 pilot. I will probably jump up to a 106 here soon as my temps get up around 370 going up long hills. get a jet kits from G9 for main and pilot worth it to have around.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
