the ticking is probably piston slap from the over usage of the piston. Also if there is scratches in the bore it creates blow by hence the hot spots on your cylinder and your piston.Get a new cylinder and piston.Those scratches will keep creating blow by and hot spots on you cylinder and piston
the ticking is gone now. im pretty sure it was from the carbon build up. a new piston and cylinder is too much money for a 20 year old scooter. after i honed the cylinder i didnt really see any scratches in it . as long as it runs well im happy, somethin this cheap doesnt have to be perfect. the main thing im concerned with now is figuring out if i have an iowa exhaust what to do with it, or just replacing it.
2001 honda elite S
2006 kawi vulcan 1600
1996 toyota tacoma
okay... i know EXACTLY WHAT HAPPEND the same thing happend to me. your jug is shot like mine was because your jug broke off a piece of your piston ring and thats the clicking. mine did the same thing. i ripped the motor apart and soaked the internals in gasoline and got the debirs out and bought a new piston because the other one was scarrd and i got another jug and some rings and gaskets and it runs golden.
1986 Honda Spree w/ pulley mod clocked in at 37mph hauling 175 lbs. Don't believe me? lets race!
ok im not sure if you guys are only readin my first post or what, but theres no ticking. the rings were completely intact when i took it apart. it is back together and running fine. concern is no longer with cylinder, piston, or ticking. my concern is my exhaust.
2001 honda elite S
1996 toyota tacoma
and also to let you know your compression brakes in. it will get about 5-10 lbs. higher after you brake in new rings and gaskets. right now i have 145 lbs. of compression
nate_lohs wrote:the ticking is gone now. im pretty sure it was from the carbon build up. a new piston and cylinder is too much money for a 20 year old scooter. after i honed the cylinder i didnt really see any scratches in it . as long as it runs well im happy, somethin this cheap doesnt have to be perfect. the main thing im concerned with now is figuring out if i have an iowa exhaust what to do with it, or just replacing it.
carbon build is caused by overjetting.. The way your piton and jug looked definitely looked rich.
