1st step on my new project
- AIO MotorSportS
- Goped
Re: 1st step on my new proyect
pics
- CAM01262.jpg (160.37 KiB) Viewed 8510 times
- CAM01261.jpg (129.45 KiB) Viewed 8510 times
Nice clean up, the ct can use a lot of porting on the down turn.
- paulpauly7
Match up that little triangle in the port with the other side .Is this a stroker ? Them some big ports .
- AIO MotorSportS
- Goped
LoveMyHonda wrote:Nice clean up, the ct can use a lot of porting on the down turn.
Yes Sir
- AIO MotorSportS
- Goped
Match where?pics pleasepaulpauly7 wrote:Match up that little triangle in the port with the other side .Is this a stroker ? Them some big ports .
No
Malossi mhr high speed bearings
AIO crankcase job
Im just starting on my AF16 project
- paulpauly7
top left in your first pic and bottom right in your second pic .where the base gasket sits the looking down into the cases the port windows have sharp corners stator side is open intake side is half blocked.
- AIO MotorSportS
- Goped
Got it,thanks, im going to match all when i get the cylinder kit and started to work on it.paulpauly7 wrote:top left in your first pic and bottom right in your second pic .where the base gasket sits the looking down into the cases the port windows have sharp corners stator side is open intake side is half blocked.
What cylinder kit do you plan on running? Your port job is looking top notch very clean ct. But like Pauly said make sure you smooth out that little triangle will cause a lot of blockage for air and fuel movement.
- AIO MotorSportS
- Goped
Got it,thanks,like i said im just startedcurtis966 wrote:What cylinder kit do you plan on running? Your port job is looking top notch very clean ct. But like Pauly said make sure you smooth out that little triangle will cause a lot of blockage for air and fuel movement.
When i get the cylinder kit im going to see what i get and what i
have to do
- AIO MotorSportS
- Goped
working on the crankcase,one step less
- CAM01280.jpg (175.15 KiB) Viewed 8435 times
- CAM01272.jpg (167.66 KiB) Viewed 8435 times
- paulpauly7
What is that stuff?
- chamisataza
- Goped
is that J-B weld original?
- AIO MotorSportS
- Goped
Is a two parts marine epoxy + high temp fiber glass fabricchamisataza wrote:is that J-B weld original?
used for 2 stroke engine on
stand up jetski
Jbweld dont work with gas n oil
- AIO MotorSportS
- Goped
No much ,just few min a week,i don't have the time to spend on this hobby like a want to.graphite9 wrote:wow, you put time into that. Kudos.
Hi AIO. Do you have a name for that stuff?
what are you building? 72cc?
