Page 2 of 2
Re: Tranny & Final Drive Fluid Change Frequencies
Posted: Thu Nov 13, 2014 6:04 pm
by Johnniespeed
Does your city have a local Scooter club ? Mine does, we have organized rides and outings.
Posted: Thu Dec 25, 2014 11:45 am
by stevemarx
Guys,
First, happy holidays to all!
I am back with a couple of questions, since I have finally made the time to perform some maintenance on our '86 Spree. Your help would be very much appreciated. Here goes:
1. The manual says '85 Spree's have 4 amp hour electrical systems and '86 models have 3 amp hour systems. We have an '86 (per the title) but the replacement battery is a 4 amp hour and not a 3. Should I be concerned? It did die after sitting for a while and I need to buy a trickle charger.
2. I cleaned the oil strainer (actually not dirty at all) and now have to bleed the oil lines. I am somewhat competent and don't want to mess it up. Any tips beyond what's in the service manual? Is it really necessary to bleed the lines?
3. Final drive clarification - I see the circled drain plug (pic below) and can drain it. Do I have to turn the scooter on its side to refill the 3 ounces? Will it flow out as I pour it in if I don't put it on its side?
Thanks again. Really appreciate all the help.
Steve
Posted: Thu Dec 25, 2014 3:28 pm
by DirtyE
I pulled my cover the other night and the oil that came out of there was disgusting. Mind you I have a 98 and its probably never been changed.
On other model scooters Ive used gasket maker. I was actually planning on using the same stuff for this gearbox as well. I forget the color RTV.
Posted: Thu Dec 25, 2014 6:30 pm
The thickness of the gasket is calculated into the end-play of the various shafts. If you use goo, the cover will get too close to the gearcase and bind the countershaft. Honda and the aftermarket (Partzilla) still stock the gaskets for about $7. Cut paper if you must, but I recommend you don't use gasket-maker liquid.
Posted: Thu Dec 25, 2014 6:45 pm
by curtis966
I agree with Wheelman the stock gasket is your best bet. With aftermarket gears sometimes the shims need to be changed for it to fit correctly.
