makeup overrange question: variator +belt + rear pulley
DirtyE
Re: makeup overrange question: variator +belt + rear pulley
Post by DirtyE »
If we get that info theoretically we could determine the proper belt legnth. And when I say we, I mean someone who's better at math than I.
98 Elite
4 strokes are for cars
Stock aero and SA vario diameter is 87.5mm. Polini-for-Dio is 90-ish. Polini -for -Ruck is 94, and big enough for 654 belt. If you run a 669, you may want 97mm. The formula is 0.5 x pi x Diameter.
AIO MotorSportS
Post by AIO MotorSportS »
683-18.2-30 malossi belt for kymco 4T
On 97mm variator malossi for ruckus
118.5 mm torque pulley for metro '14
My set up
LMH
Post by LMH »
AIO MotorSportS wrote:683-18.2-30 malossi belt for kymco 4T
My set up
Have you had it running and riding yet?
AIO MotorSportS
First run,42g-1000 see pic
DirtyE
Post by DirtyE »
When you say "torque pulley" are you referring to the torque driver or the rear pulley system?
98 Elite
curtis966
Post by curtis966 »
Lovemyhonda didn't I read once that you like the polini ruck variator with the malossi ramp best? As a variator set up.
And what are the specs of the malossi for zx belt?
DirtyE
Post by DirtyE »
Can anyone tell me if the torque driver slots on the zx pulley(where the locator pins slide in) are bent or straight? You know whether the grooves open at one angle initially then move to another angle?
98 Elite
